So we have our second trip in, already posted about brake controller issues,  but since they are activating, I've decided to live with the display on the controller not showing connected.
The other problem we had concerned the Alde hot water.   We had full connections, and water was working fine,  holding tank was empty.  I got a nice hot shower after a bike ride, but 3 hours later when my DW came in to get one, the water was cold.   I had the Alde set to hot water only on the 3rd lever and heat was off as well as propane.  I did not touch the controls after I took a shower, so not sure why there would not be hot water.   I flipped the switch off and back on, and we had hot water later.
The next day before we unhooked,  I put water in the holding tank, and assumed the Alde was full of hot water.  I thought there were 6 gallons of hot in the Alde, but there must be much less.   That afternoon I took a very quick shower and thought I had saved plenty of water,  but when she got back found out we were basically out of water.
So,  2 questions.  On electric,  the only setting I need to use should be the the right lever and set to the water symbol only, when cabin heat isn't necessary?
and How much water does the Alde hold?
Other than being clean while DWifey was not,  it was still a great trip.  She wasn't too mad.
Without one of those switched on, the Alde won't work.
I thought I understood that Alde panel. Now I think I do.
2022 Ford F350 Tremor | 2022 Cirrus 620
Best to let the DW have the first shower, methinks. B-)
