Now, we've been camping for 42 years, and first thing in the morning we lug out the coleman stove, put on a kettle, and heat some water. From there, we could go to the instant (yuck), or better, we could get out our carafe, put the funnel on top with coffee grounds, and run it through.... Ahhh.... great. Now, with a camper with have a few more options. We can continue as before outside. Or, we could do the same procedure inside. I don't see an electric maker working, keurig or otherwise, unless hooked up to shore power. I'm sure there is a vast majority of people here that are hooked on the Java. I would like to hear from them....
Terry & Jody... 2025 Honda Ridgeline RTL
2016 NuCamp 320 T@B Max S
T@bbey Road
Appleton, WI
0 ·
Eric aka: Lone Wolf
Every large trucker oriented gas station usually has dc operated appliances on the shelf also.
Off to do some more shopping....
T@bbey Road
Appleton, WI
T@bbey Road
Appleton, WI
Hate dealing with the grounds - Even with the perc but at least they're contained in the filter.
I use a collapsible pour over something like this one http://www.amazon.com/Kuke-Silicone-Reusable-Dripper-Brewers/dp/B01AWD9DFC/ref=sr_1_4?ie=UTF8&qid=1464193401&sr=8-4&keywords=collapsible+pour+over+coffee+filterThe French press is a pain for ease of cleaning. The Aeropress is simpler that way, paper filter, a quick rinse will do for 4 out of 5 cups. Then I'll take some dish soap to it.
Finding good ground coffee can be a challenge, in some of those 'backwater' towns that are so nice to find.
No fuss, no muss and I have my one drug addiction taken care of - instantly.
Very happy with this model. Put a K-cup in the base, fill with boiling water, place over your coffee mug, and gently press down on the top. Takes about 5 presses to get all the water through the K-cup and into your mug. ZERO clean-up. Simply remove the K-cup and toss in the trash. Use a stronger blend than what you're used to. Only $14 at Amazon.com
Wonder how many Kcups I'd go thru in a day.
http://www.amazon.com/GSI-Outdoors-Stainless-Percolator-Silicone/dp/B001LF3I2K
...can some of you hear the Folger's commercial music?
The MyJo is intriguing...our favorite local coffee, Durango Joe's, now comes in pods...hmmm.
J.D. & Sue
@PXLated, what's your coffee budget like?
We use an old-school percolator with paper filters (not perfect). The reviews I read about 12v coffee makers say they take a long time to brew. I'd be chewing my arm off before I had coffee made. I remember seeing a pic of a Nespresso on someone's T@B counter. Wonder how many watts that puppy pulls? We used to have an old Saladmaster 110v percolator, and we loved the coffee it made, but it sounded like someone moaning while it brewed. I will not say more about that.
Sterling, VA
Sterling, VA
Haven't seen Starbucks instant in stores - Have to get it at a Starbucks?
Just looked up the Myjo, pretty cool device. @PXLated , it also has a filter that you can place fresh grounds in, which may be easier for you to get, and cheaper long term. Smaller and easier to clean then the perk.
Sterling, VA
2016 M@x S Sofitel - The T@bahoula
T@bbey Road
Appleton, WI
