Dewinterizing Problem-Water pouring out drain behind tire opposite the door--2016 Tab Outback Max S
BertBert Member Posts: 87
Where is the valve that will keep water from pouring out of the drain pipe that extends down behind one of the water tanks? It's about a foot from the side of the Tab opposite the door and behind the tire. I believe that I have the Alde hot and cold water drains closed and the freshwater tank drain. What's left? The new Tab was winterized by the dealer, so I don't know what they did to open the system up when draining the water (or what I need to do to close it). I won't be filling the Tab with water until I figure out what's open.
    Can you post a photo of your pipes and valves next to the Alde?
  • db_cooperdb_cooper Member Posts: 747
    Ours has a plastic yellow valve that has to be flipped, and is not pictured in the winterizing picture.  Look close to the Alde unit for a flat plastic valve lever.
  • RollingLagrimaRollingLagrima Member Posts: 435
  • BertBert Member Posts: 87
    Thanks, db_cooper. I'm betting that's it. I just took the trailer back to the storage facility, so I won't know if you pegged it until we're bringing the Tab home to prepare for a trip.
  • ScottGScottG Administrator Posts: 5,654
    Assuming your '16 is laid out similar to my '15, the location you describe is consistent with the valve indicated by db-cooper and RollingLagrima. It's the drain for the Alde's hot water reservoir.
    Note that in the photo above, the drain is closed (which is the position you want it in for normal operation). To open it, you flip the little yellow lever up so it is perpendicular to the pipe.
    I still love my label maker to label each of the valves and using arrows to indicate "summer" or "winter".  i certainly can't remember from spring to winter which goes which way ;)
