Yes, it fits on the floorboard behind my driver's seat. It takes up little room. I did use it last year when I had to change a tire.PXLated said:Verna - Do you carry it with you?
Curious - How many that do own one do carry it on the road.
Now, it's a fact that I'm a minimalist and carry as little as possible but I still carry way to much and need to cut back. Still trying to get to that stage of carrying only stuff I use on a regular basis.
PXLated is a full-timer. I spent 3+ months in AZ in the winter plus normally 4-6 weeks somewhere in the summer. It's best if I keep mine with me.Ramrod said:Eye ball it on the road and check your torque at home. Harbor Freight torque wrench works perfectly fine
Take your middle finger tip, touch your thumb tip to make a circle. That's about how big around it is in the package. 14" to 18" long. Put it in the passenger seat tucked between the seat and the back of the seat. Then you have to remember where it is!PXLated said:Takes up little room + takes up little room + takes up little room + takes up little room ends up (in my case) taking up a lot of room :-)
Note that torque wrenches come in different ranges, so if you do get one, make sure it covers the value specified for your lug nuts.Photomom said:Apparently I need to acquire a torque wrench for my lug nuts. As I have no experience whatsoever with this, would someone please recommend a specific one that is appropriate and not too costly?
Try planning for 3 months in AZ for the winter. Three seasons of clothes, but only a few fall/winter items, mostly summer shorts and t-shirts. And then, the "what-if" syndrome comes in and you throw that in, too. Oops--no more room! I take less each trip, but I still have to tell myself there are stores in AZ that sell stuff if I need it! The same goes for food....AZ does have food and bottled water!TerryV6 said:Well, this certainly old for most of you, but I just saw it. You come down with Gas, or, Gear Aquisition Syndrome.. While I've only been out a few times so far, I can see better what I really need and what can stay home. There is plenty of space, but it is precious and not to be wasted.
True, there are some trips I do travel very full, some I don't. But my truck can handle it and more. Honestly, if I were full timing and traveling, I'd have much less. Most of my trips are to single destinations for an extended amount of time, so I like to be comfy.PXLated said:Carol - Have seen your setup, you don't exactly travel light - I swear some of you have uHaul stepvans for your TVs :-)
That sounds about right for torquing a lug nut. If you are in the market for a wrench, though, note that this is 90 foot-lbs. Some wrenches are rated in inch-lbs.Verna said:
