Jockey Wheel Issue on LG T@bs?
jkjenn
jkjenn Member Posts: 6,425
edited March 2014 in Trailer & Towing
I have read in several places about the problem of the jockey wheel falling down during transit. Is that unique to the older T@bs or is it an issue on the new ones, too? Do owners of the new T@bs tie theirs up while in transit as a precaution?
  • I just pull the pin and remove it when in transit .... takes about 30 seconds.
  • jkjenn
    Good thought... seems like a better idea.
  • Wanderoo
    Wanderoo Member Posts: 553
    Jenn -- That's what I do, too. It gives me better peace of mind. I know it's another thing to remember before you get ready to tow, but it will all become habit after a few times. B-)
    Beth, 2015 Toyota Tacoma (Ramblin' Rose), 2014 T@B S M@xx (ClemenT@B)
  • Cyclonic
    Cyclonic Member Posts: 1,232
    As others have stated, best practice is to remove the wheel while in transit.
    Someone can correct me if I am wrong, but I don't believe the jocky wheels on the AL-KO frames (which are what the Dutchman T@Bs are built on) are removable, but they seem to be easily broken.
    Sterling, VA
  • Michigan_Mike
    If you get into a low area or dip while pulling your trailer you risk not only damaging the jockey wheel, but also the trailer jack should you hit something. I have always removed my jockey wheel on my Silver Shadow or any trailer I tow. I either store it in the back of my tow vehicle or in my diamond plate aluminum storage box. I keep the pin inserted in the wheel too so I don't misplace it. I also carry along a large square block of wood too and lower the jack down onto the wood block when I reach the desired location when I am camping. For me personally I use my jockey wheel more around my home then at the campground.
  • jkjenn
    Thanks for the explanation, Mike. I will plan on removing mine, too.
  • jbug10
    jbug10 Member Posts: 156
    JkJenn, when I first started researching T@bs, I remember reading the old Dutchman T@bs had a jockey wheel that folded up and people had to bungee them down to keep then from dropping down. I think that might be what you are referring to. LG uses a different hitch and we just have to remove the wheel.
    June; 2013 T@b "Fant@bulous"; 2016 Jeep Grand Cherokee; one kayak and one bike
  • TABaker
    TABaker Member Posts: 432
    It's a good idea for owners of Dutchmen T@Bs to bungee the wheel.  Some have drilled a hole and use a pin.  If you don't tighten enough after lifting into it's riding place, it can jiggle loose and become damaged.
    Crystal & Daisy, a yellow 2007 T@B Q previously towed by a 2008 Jeep Liberty, and currently towed by a 2016 RAM 1500.
  • Michigan_Mike
    LOL!!!  Even a cheese colored jockey wheel to eh?   :))
  • TABaker
    Well of course!
  • jkjenn
    Thanks, everyone. Yes, exactly as Crystal,put it, it was regarding the old models. Taking it off sounds easy enough!
  • joansie
    joansie Member Posts: 19
    Cut a piece out of a piece of 2 inch PVC pipe so it snaps over the tube and is tight against the crank. Hold everything in place.
    There was an error rendering this rich post.
  • KarenNGeorge
    KarenNGeorge Member Posts: 6
    On the 2014 models of T@B's I find my hitch ball is low when aligning to my trailer hitch. I keep the trailer hitch tilted high to maintain drainage from rain and moisture. So when I've back up to lower the hitch there is not much room to remove the wheel. Has anyone built up the platform that holds the jack?
    George
    2014 T@B "S"
    2014 T@B "S"
    Bluffton, SC
  • TABoo
    TABoo Member Posts: 30
    If you don't plan to need the wheel, I would suggest using a jack stand. I found that at some sites to level the trailer I could not get low enough with the wheel and this works great.
