New T@B upgrades
RollingBnB
Member Posts: 322
Just picked up our 2017 T@B MAX S. They made some changes to her. They are using a new 3 way frig, (still Norcold) no more vents in front, two on the side now and no more aux fan. For those buying new hinges for the overhead cabinets, they now stay open by themselves. And most important, it still fits in our garage Can't wait for T@Bazona
2020 Tiffin Open Road
2020 Nissan Versa Toad Alan & Patty
Southern Az
5
Pics, need pics :-)
Oh, and, congrats.0 -
Do the cabinets stay open because the hinges are spring-loaded and hold them open, or do they have some kind of struts or stays? Could you post a picture? We have a 2017 T@b MAX S Outback, and are not happy with the hinge-strut combination, which caused the hinges to pop out. We contacted PV/NuCamp, and they told us to glue the hinges in; if that didn't fix the problem they said they would send us new doors. If they have changed the hinges and corrected the problem, I think we'll ask for new doors.Slick 'n' Slim
2017 Max S Outback, 2012 Toyota FJ Cruiser0 -
TexasSlim said:Do the cabinets stay open because the hinges are spring-loaded and hold them open, or do they have some kind of struts or stays? Could you post a picture? We have a 2017 T@b MAX S Outback, and are not happy with the hinge-strut combination, which caused the hinges to pop out. We contacted PV/NuCamp, and they told us to glue the hinges in; if that didn't fix the problem they said they would send us new doors. If they have changed the hinges and corrected the problem, I think we'll ask for new doors.
They have struts that hold them open, probably small springs inside.2020 Tiffin Open Road2020 Nissan Versa Toad
Alan & Patty
Southern Az0 -
Pics and model number for the new Norcold would be nice. Does it have a freezer?2016 Outback 320
OutbackAZ said:Pics and model number for the new Norcold would be nice. Does it have a freezer?
No freezer. Model is N180.3
Alan & Patty
Southern Az0 -
Very nice looking combination. Congratulations!
Sterling, VA0 -
It's lovely!
Red and White, 2017 Max S being towed by a 2014 Honda Ridgeline. Hello Mountains!0 -
Just guessing - model N180.3? If so, it is a 1.8 cu ft fridge versus a 1.7 cu ft that came on ours. Also setup for right side venting versus the dual front and side venting of the model 323.2022 T@B 400 BD
2019 Ford F-150 3.5L Ecoboost with Long Bed0 -
Yes venting is on right side thru 2 new removable rectangular vents2020 Tiffin Open Road2020 Nissan Versa Toad
Alan & Patty
Southern Az0 -
Wonder if the burn box and thermocouple are easier to get to. On mine they are in the far back left corner.0
Notice the gray left side access panel is gone with the new unit. Must mean the burn box and thermocouple are in a new location. Hmmmmmm?2016 Outback 320
And here is the new unit from the Norcold website:
http://www.thetford.com/product/n180-3/
Really like that wood fascia.
2016 Outback 320
I wonder if the Tab door being wide open will interfere with venting.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
I removed the fascia on an old one and added birch veneer on a two way. I would assume that this could be done on other older models.
But losing the access panel on the new one is much nicer looking than other 3 ways.
. 1 -
Burn box and thermocouple aren't any more convenient - still in far back, just opposite corner...
Can't tell from Rolling B's photo if that black access panel is fitted with a wood veneer to match the door fascia. Also, I wonder what the third rotary knob is for? Even with moving the working parts to the right, I can still see an advantage to having an exhaust fan on the upper vent grill. Much cleaner visual having the front two exhaust vents eliminated. Hard to tell from the photo above, but did this new position eliminate the need for the cooling fan under the coils?2016 Outback 320
Your Norcold link mentions the "insert panel door to match interior"OutbackAZ said:Can't tell from Rolling B's photo if that black access panel is fitted with a wood veneer to match the door fascia. Also, I wonder what the third rotary knob is for? Even with moving the working parts to the right, I can still see an advantage to having an exhaust fan on the upper vent grill. Much cleaner visual having the front two exhaust vents eliminated. Hard to tell from the photo above, but did this new position eliminate the need for the cooling fan under the coils?Crystal & Daisy, a yellow 2007 T@B Q previously towed by a 2008 Jeep Liberty, and currently towed by a 2016 RAM 1500.0 -
The knobs are 1 select ac,dc gas. 2 ac thermostat, 3 gas thermostat.2020 Tiffin Open Road2020 Nissan Versa Toad
Alan & Patty
Southern Az1 -
PXLated said:Burn box and thermocouple aren't any more convenient - still in far back, just opposite corner...
The lower vent opens up right at burner level and they use twist latches just like the bigger trailers.
Alan & Patty
Southern Az0 -
RollingBnB - Ok then, that solves the problem with the current fridge where you have to take the dang thing out. A real pain.0
RollingBnB said:The knobs are 1 select ac,dc gas. 2 ac thermostat, 3 gas thermostat.
I imagine the dual vents work on convection alone (no exterior fan needed).
2015 T@B Max S (White/Silver) -> 2014 Ford Escape 2.0L (turbo, AWD, factory tow)0 -
Here's a quick and dirty screen grab from a dealer video. I really like the new matching door panel insert, I saw it in person the other week. Looks sharp. The side remains black.
2018 T@B Max S silver and black (aka TadT@B), Full-timing since July 2017
It appears to me that Norcold has addressed some of this issues folks have been having with this model 3-way. It will be interesting to see how it works after a good time frame in use. I really like the fact that the workings are much more accessible through the outside removable vent covers.2016 T@B MAX S-aka: WolfT@B
Eric aka: Lone Wolf0 -
Very nice!! Is that a table bracket to the left of the door? If so, did you order that as an extra?Sn@pDog, 2017 Outback, Silver w/black trim0
I like the outside finish better0
SnapDog said:Very nice!! Is that a table bracket to the left of the door? If so, did you order that as an extra?
The dealer we ordered from does a complete package, the only extra we asked for was the porthole window in the bathroom and there was no charge.2020 Tiffin Open Road2020 Nissan Versa Toad
Alan & Patty
Southern Az0 -
I just ordered the Tab Basic S and asked for the same access panel $395 and lagun table bracket $125 I think...sounds like you dealer has put together a nice package of extras.2017 Tab Basic S Silver on Silver with Sofitel Cushions....upgraded from 2013 LG 5W....Towed by a 2016 Sorento V6 AWD w/5000lb tow capacity. Dave S. married to Jen aka SanDiegoGal We pull a Tab but live in a 2014 Airstream International Signature 27 FBQ...Talk about embracing a trailer lifestyle.0
dsatwork said:I just ordered the Tab Basic S and asked for the same access panel $395 and lagun table bracket $125 I think...sounds like you dealer has put together a nice package of extras.
We thought so too. U need to fix your delivery date in your sig. Can a CRV tow 2k lbs?2020 Tiffin Open Road2020 Nissan Versa Toad
Alan & Patty
Southern Az0 -
Alan and Patty - Please say you'll be bringing White Castle hamburgers to the T@bazona potluck!
2016 Outback 320
