New T@B upgrades
RollingBnB
RollingBnB Member Posts: 322
edited December 2016 in Modifications & Upgrades
Just picked up our 2017 T@B MAX S. They made some changes to her. They are using a new 3 way frig, (still Norcold) no more vents in front, two on the side now and no more aux fan. For those buying new hinges for the overhead cabinets, they now stay open by themselves. And most important, it still fits in our garage Can't wait for T@Bazona
2020 Tiffin Open Road
2020 Nissan Versa Toad
Alan & Patty
Southern Az
«13
  • Nomad
    Nomad Member Posts: 7,209
    Pics, need pics :-)
    Oh, and, congrats.
  • TexasSlim
    TexasSlim Member Posts: 5
    Do the cabinets stay open because the hinges are spring-loaded and hold them open, or do they have some kind of struts or stays?  Could you post a picture?  We have a 2017 T@b MAX S Outback, and are not happy with the hinge-strut combination, which caused the hinges to pop out.  We contacted PV/NuCamp, and they told us to glue the hinges in; if that didn't fix the problem they said they would send us new doors. If they have changed the hinges and corrected the problem, I think we'll ask for new doors.
    Slick 'n' Slim
    2017 Max S Outback, 2012 Toyota FJ Cruiser
  • RollingBnB
    They have struts that hold them open, probably small springs inside.
    Alan & Patty
    Southern Az
  • Tabaz
    Tabaz Member Posts: 2,420
    Pics and model number for the new Norcold would be nice.  Does it have a freezer?
  • RollingBnB
    No freezer. Model is N180.3
    Alan & Patty
    Southern Az
  • Cyclonic
    Cyclonic Member Posts: 1,232
    Very nice looking combination.  Congratulations!
    Sterling, VA
  • LauraRey
    LauraRey Member Posts: 338
    It's lovely!
  • JohnDanielsCPA
    JohnDanielsCPA Member Posts: 238
    Just guessing - model N180.3?  If so, it is a 1.8 cu ft fridge versus a 1.7 cu ft that came on ours.  Also setup for right side venting versus the dual front and side venting of the model 323.
    2022 T@B 400 BD
    2019 Ford F-150 3.5L Ecoboost with Long Bed
  • RollingBnB
    Yes venting is on right side thru 2 new removable rectangular vents
    Alan & Patty
    Southern Az
  • Nomad
    Wonder if the burn box and thermocouple are easier to get to. On mine they are in the far back left corner.
  • Tabaz
    Notice the gray left side access panel is gone with the new unit.  Must mean the burn box and thermocouple are in a new location.  Hmmmmmm?
  • Tabaz
    And here is the new unit from the Norcold website:
    http://www.thetford.com/product/n180-3/
    Really like that wood fascia.
    I wonder if the Tab door being wide open will interfere with venting.
  • mash2
    mash2 Member Posts: 584
    I removed the fascia on an old one and added birch veneer on a two way.  I would assume that this could be done on other older models.
    But losing the access panel on the new one is much nicer looking than other 3 ways.
  • Nomad
    Burn box and thermocouple aren't any more convenient - still in far back, just opposite corner...
  • Tabaz
    Can't tell from Rolling B's photo if that black access panel is fitted with a wood veneer to match the door fascia.  Also, I wonder what the third rotary knob is for?  Even with moving the working parts to the right, I can still see an advantage to having an exhaust fan on the upper vent grill.  Much cleaner visual having the front two exhaust vents eliminated.  Hard to tell from the photo above, but did this new position eliminate the need for the cooling fan under the coils?
  • TABaker
    TABaker Member Posts: 432
    Your Norcold link mentions the "insert panel door to match interior"
  • RollingBnB
    The knobs are 1 select ac,dc gas. 2 ac thermostat, 3 gas thermostat.
    Alan & Patty
    Southern Az
  • RollingBnB
    The lower vent opens up right at burner level and they use twist latches just like the bigger trailers.
    Alan & Patty
    Southern Az
  • Nomad
    RollingBnB - Ok then, that solves the problem with the current fridge where you have to take the dang thing out. A real pain.
  • TabberJohn
    TabberJohn Member Posts: 588
    I imagine the dual vents work on convection alone (no exterior fan needed).
  • HR_Taly
    HR_Taly Member Posts: 119
    Here's a quick and dirty screen grab from a dealer video.  I really like the new matching door panel insert, I saw it in person the other week.  Looks sharp.  The side remains black.
    2018 T@B Max S silver and black (aka TadT@B), Full-timing since July 2017
  • LauraRey
    I was wondering the exact same thing.
  • ericnliz
    ericnliz Member Posts: 4,437
    It appears to me that Norcold has addressed some of this issues folks have been having with this model 3-way. It will be interesting to see how it works after a good time frame in use. I really like the fact that the workings are much more accessible through the outside removable vent covers.
  • SnapDog
    SnapDog Member Posts: 53
    Very nice!! Is that a table bracket to the left of the door? If so, did you order that as an extra?
    Sn@pDog, 2017 Outback, Silver w/black trim
  • Fatman1966
    Fatman1966 Member Posts: 149
    I like the outside finish better
  • RollingBnB
    The dealer we ordered from does a complete package, the only extra we asked for was the porthole window in the bathroom and there was no charge.
    Alan & Patty
    Southern Az
  • dsatwork
    dsatwork Member Posts: 744
    I just ordered the Tab Basic S and asked for the same access panel $395 and lagun table bracket $125 I think...sounds like you dealer has put together a nice package of extras.
  • RollingBnB
    We thought so too. U need to fix your delivery date in your sig. Can a CRV tow 2k lbs?
    Alan & Patty
    Southern Az
  • Tabaz
    Alan and Patty - Please say you'll be bringing White Castle hamburgers to the T@bazona potluck!
