LED 7 Pin Tester
Sharon_is_SAM
Member Posts: 10,061
Santa left me a Curt LED 7 pin tester as a stocking stuffer. We tested the TV 7 pin connector this evening and found that the BU (backup light) never lit up when placed in reverse. Now, I know the Tab does not have backup lights, but, do you think I got a bad one or is my 7 pin wiring need a revision?Thanks, Sharon
Whoever installed your 7 pin probably didn't run a wire for the backup lights. My guess is it is not the tester.
By applying -12 volts to the ground terminal and +12 volts to the backup light terminal you can test the tester.- Hash T@B Fun
"By applying -12 volts to the ground terminal and +12 volts to the backup light terminal you can test the tester" ... Huh? Could you come and do that for me :-)
You bet happy to.PXLated said:"By applying -12 volts to the ground terminal and +12 volts to the backup light terminal you can test the tester" ... Huh? Could you come and do that for me :-)- Hash T@B Fun
Could you be here on Thursday? :-)
Dale, how do I do this?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
You are coming to Tabazona right?PXLated said:Could you be here on Thursday? :-)- Hash T@B Fun
Dale, assuming there is no back- up wiring, not a problem, correct?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Find someone with a tool called a multimeter. If they know how to us it they can test it for you. Most employees at OReillys or Auto Zone could test both the plug and the tester. Most U Haul dealers could help as well.SAM said:Dale, how do I do this?- Hash T@B Fun
CorrectSAM said:Dale, assuming there is no back- up wiring, not a problem, correct?- Hash T@B Fun
Thanks Dale!Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Tabazonna - Nope, won't be in the area.
Maybe another time.PXLated said:Tabazonna - Nope, won't be in the area.- Hash T@B Fun
The auxiliary/backup terminal is typically the center pin on the 7-pin connector. Color schemes seem to vary, but the T@B owner's manual (such as it is) indicates that this is a yellow wire in the T@B harness.
If you look at the photo below, you can see the yellow wire from the harness enters the main junction box in the lower right and is connected to a terminal that is not connected to anything else.
While this this doesn't answer the question of whether your TV is wired correctly, it does confirm that the auxiliary/backup circuit--while available--is not used in the T@B (at least not in my 2015 S).
Thanks Scott. So, those of us with Tabs with electric brakes actually use 6 out of the 7 pins. I think MichiganMike has the same 7 pin tester and I wonder if he sees the same absense of light on the tester. Mike?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
I went out and checked mine by having my son start the car and putting it in reverse (carefully, with the brakes on!) while I checked. I have the Tekonsha tester, same deal. I imagine that whoever installs your 7 way connector would hook up the backup light if requested. Ours did not as we had no expectation of using it.
John and Henrietta, Late 2016 T@B S Max in Western New York -
It's interesting that this is often called the "auxiliary" pin rather than the "backup light" pin. Apparently it can have multiple uses, depending on how it is wired. Perhaps that's why it is left unpowered on some receptacles?
https://www.etrailer.com/question-7194.html
https://www.etrailer.com/question-112339.html
- 915 Tips & Tricks
