Sequoia table leg system
Does anyone have experience with the Sequoia Leg System?  Is it stable for a T@B full size table?  Is it convenient and easy to use?
I think PV used this style leg in some T@Bs they built.
I'm considering changing the base on my DM table.
  • mash2
    mash2 Member Posts: 584
    I used for a while, but didn't really like  that much.  Took mine off and switched to the Lagun mount and have been much happier with the Lagun setup.  The leg was too tall for my taste (27 inch).
    Having said this. it did work.   The locking bracket was a bit finicky.... needed to be locked down tight to get table stable and was sometimes difficult to loosen after it was tightened to stabilize the table.    Also wish I could have found a 25.5 inch leg (while listed as available, could only find the longer arm on line).
  • RZRBUG
    RZRBUG Member Posts: 890
    Although the concept and idea is good, I found that the floor base to be inadequate for heavy use.  The base is made of cast aluminum and is prone to cracking and breaking.
    Happy Trails Y'all
    States Visited Map
  • Dalehelman
    If you are going to secure to floor I would recommend through bolting with large fender washers on the bottom side
    1. Hash  T@B Fun
  • moosemama
    moosemama Member Posts: 26
    We installed one and aren't crazy about it.  The table does not feel stable.  If you do try it, one word of caution:  make sure you screw the collar all the way down at the base.  Turning the table to get in and out of the seats caused ours to loosen, which we didn't discover until setting a full glass of red wine down on the table!  It went everywhere.  If you look closely,  you can still see a pink shadow on the cushions....
    AZ - 2016 T@B-S Outback Silver/silver
  • rfuss928
    rfuss928 Member Posts: 1,197
    edited January 2017
    Everyone, thanks for the feedback.  This confirms what I thought I had heard before.  I think we'll stick with the original folding base and legs (so many others dislike).  I don't find it difficult to use and it makes a very stable table when up.
    Our springer spaniel, Bella, sometimes crawls under to the "way back" when the bed is made.  I thought a little more room under the table in either position would be nice for all of us.
    The Sequoia leg does not seem to be what we want.
  • Ratkity
    Ratkity Member Posts: 3,770
    Beeeeeautiful pup!!!! :heart:
  • marknjudy
    marknjudy Member Posts: 378
    I've been giving this a lot of thought I and I believe I've decided to do what PXL, RZRBUG and others have done and use a lighter weight folding table instead of futzing with the Lagun system or anything else. It's lightweight, can be used outside and easily taken out of the way.
    Mark - 2016 T@b Max S (Silver/Red), 2012 F-150
