How many degrees is the arc in the roof for flexible solar
dsatwork
Member Posts: 744
This is the only post I could find that discussed the arc in the roof.
capewoods said:Great! Having just permanently mounted two Renogy 100W flexible solar panels to my T@B clamshell, I come across this post. I love it so far, but I guess I'm going to have to just wait and see what happens. The bend is less than the 30 degrees they said they could accommodate. I also used a permanent tape that I know is going to take the roof with it if I ever did try and get them off.
2017 Tab Basic S Silver on Silver with Sofitel Cushions....upgraded from 2013 LG 5W....Towed by a 2016 Sorento V6 AWD w/5000lb tow capacity. Dave S. married to Jen aka SanDiegoGal We pull a Tab but live in a 2014 Airstream International Signature 27 FBQ...Talk about embracing a trailer lifestyle.
For both the front and rear curves, the width of the arc is just about 5x the height of the arc. That makes the angle defined by the arc ~87 degrees in both cases.
However, I'm not sure that's the information you are looking for. The "sharpness" of a curve depends on its radius rather than its angle; and to get that you'd need to take your tape measure out to the T@B.
I don't know what the "30 degrees" is referring to. Though not certain, I highly doubt you can bend any panel into that severe an angle!
Is Renogy back in the flexible panel business? They took them down over a year or so ago. I have not had any problems but am curious.
John
2007 T@B
Rockford, IL
jcfaber1 said:Is Renogy back in the flexible panel business? They took them down over a year or so ago. I have not had any problems but am curious.
John
No - but there are plenty of others that are in, now, including Zamp. They are well under $200 for a 100w panel, now.2021 T@b 320 Boondock "Mattie Ross" | 2021 T@b Nights: 239 | Total nights in a T@b 455 | 2022 Jeep Grand Cherokee L Overland | T@b owner since 2014
- 915 Tips & Tricks
