Keeping the 7 pin dry
Sharon_is_SAM
Sharon_is_SAM Posts: 10,035
edited April 2020 in Trailer & Towing
I have a cover for the TaB side of the 7 pin, but unless you keep it upright, it collects water. We used zip ties and a fist clamp.  This is actually the end of our brake controller.
  • TerryV6
    TerryV6 Posts: 1,101
    A clip of some kind might be a good idea...
    2016 NuCamp 320 T@B Max S
    T@bbey  Road
    Appleton,  WI
  • gophergrad
    gophergrad Posts: 115
    thanks - I did not know covers existed (I wondered), but now I have one Amazon Priming its way here
    2017 CS-S Max (Silver & Yellow), TV 2019 Ram 1500
    Camping under the Big Sky
    The fist clamp worked nicely.  We had 2 left over from an attempt to create a mount for the stabilizer crank.
  • ChanW
    ChanW Posts: 3,165
    edited June 2017
    I just make sure my cable is hanging downwards, so no water goes in....  ;)
  • Ratkity
    Ratkity Posts: 3,770
    Ditto. Never had a problem.
  • Homebodyatheart
    Homebodyatheart Posts: 2,518
    Before a wind and rainstorm I put a small plastic bag over with rubber band holding it on. Worked fine!
  • Michigan_Mike
    Michigan_Mike Posts: 2,858
    edited June 2017
    I know there are protective devices out there for this purpose (protecting against water entry into wires & connectors) but have never experienced any issues/problems with any trailers owned over the years (via the wiring), nor water migration into the wiring itself.
    I will add however that in the utility industry there is an issue with water wicking (entering cables)  into exposed aluminum cable ends that are left exposed and open to the elements (e.g., via rainfall, laying in ground water, etc.) and that water that does enter into an aluminum conductor creates a chemical reaction that can break down aluminum, cause aluminum to oxidize, turn it to a powder, the cable and jacket eventually swell up and will eventually causes a cable failure.  To eliminate this from happening cable ends are capped off with a heat shrink cap after the cable is cut and the ends are protected from any moisture entering the cable ends.
    Copper conductors are more forgiving but will react with aluminum conductors (when spliced together) and this requires care and using connectors that are designed for the application undertaken.  I believe that any means of protecting a 7-pin cable connector from water entry whether the end is protected with a cap, covering it up with plastic or merely hanging the end downward to protect it from the elements and water are all good and preventive means of keeping it in operable/safe condition.
  • Homebodyatheart
    I take back my previous self assurance. After incredible deluges this weekend the rain got into the plastic bag anyway. I thought of @ChanW remark, and going to try it next time. Sigh...
  • Luckyj
    Luckyj Posts: 286
    Just apply dielectric grease or silicone to the conectors, it will not matter if it is wet or dry.
    TV 2005 jeep TJ unlimited
    Alaskan Malamuthe on board!
    Les Escoumins and Petite-Riviere-St-Francois QC
  • ericnliz
    ericnliz Posts: 4,437
    @Luckyj, Absolutely agree. Both ends, including the connector for the tow vehicle. reduces corrosion as well, so it's a win-win. I use it on my shore power plug as well, including a little on the threads of the connector. Makes it much easier to screw the connector on. Dielectric grease is absolutely your friend on all electrical connectors. I just put some on a Q-TIP to apply it. Keep a little plastic container of it in my tool section of the trailer. :)
    2016 T@B MAX S-aka: WolfT@B
    Eric aka: Lone Wolf
