How to attach a link within your discussion
Sharon_is_SAM
Member Posts: 10,035
I have failed the T@B Forum "link" too many times. Am I wrong to try and paste it into the url box that comes up when you select the link icon? Whenever I do that, I get a http and a https. What am I doing wrong?
@SAM, I took a look at your recent post with the broken link. I think the problem--as you noted--is that the address in the url box is "http://https//..."
Any address should only start with one of these or the other. You may have left the default http in place when you pasted in your link.
Regardless, if you are simply pasting a full link into a post, I don't think you even need to twiddle with the link icon. The http automatically identifies what you have pasted or typed as a hyperlink (just like it did in my first sentence...)
If I understand correctly, the link icon is for when you want to do something like this!
So don't bother with the link icon, just copy and paste into the body of the discussion. OK. Thanks!
@SAM, I tried to fix your link but it still doesn’t work. Hummmmmm......I’m terrible with links, too. I think it might be Vanilla’s dislike of all things AppleVerna, Columbus, IN
I don't know why @SAM 's link didn't work, but I think this is the unit he's pointing to:Verna said:@SAM, I tried to fix your link but it still doesn’t work. Hummmmmm......I’m terrible with links, too. I think it might be Vanilla’s dislike of all things Apple
https://www.amazon.com/Viair-00073-Heavy-Portable-Compressor/dp/B0012WHBSO
Well, my link is identical to Marceline's and mine does not work and it was from a Dell PC, Verna! Scott said to just copy and paste into the body of the comment, but I still want to know how to use the link icon.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1
When I point my cursor at your link and click "copy link address" (instead of just clicking on your link) it shows this as your link when I paste it into notepad:SAM said:Well, my link is identical to Marceline's and mine does not work and it was from a Dell PC, Verna! Scott said to just copy and paste into the body of the comment, but I still want to know how to use the link icon.
http://https//www.amazon.com/Viair-00073-Heavy-Portable-Compressor/dp/B0012WHBSO
For some reason there's an extra "http://" at the beginning.
I don't know why this is.San Francisco Bay Area | 2013 CS-S us@gi | 2015 Toyota Tacoma PreRunner Double Cab
I originally copied and pasted into the link address box and it then showed up like that.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
2015 T@b 320S Maxx Outback, aka "Alie Cat"
TV: 2012 Honda Ridgeline
Alice
Crozet, VA0 -
When you use the link address box menu option, it automatically fills in the "http://" at the beginning, so if you don't erase that "http://" before pasting your link you end up with "http://https//....."SAM said:I originally copied and pasted into the link address box and it then showed up like that.
Ok, thanks. Next time!Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
I fixed it by copying and pasting Marceline's link. Geesh!Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
The link icon is for when you want to make a word or phrase of plain test into a hyperlink. See the example in the last sentence of my post above.SAM said:Well, my link is identical to Marceline's and mine does not work and it was from a Dell PC, Verna! Scott said to just copy and paste into the body of the comment, but I still want to know how to use the link icon.
In that case, I highlighted the word "this" then used the link icon to assign the address "https://tab.nucamprv.com/"
Now when you click the hyperlinked word, you go directly to the nuCamp web site!
Of course, just pasting a link into the body of your text work equally well. This link icon just allows you to polish the presentation a bit and reduce the clutter created by sometimes long web addresses.
Thanks for that Scott! There is hope now
. Now I need to learn to use the emoticons! Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1 -
I only recently discovered the hyperlink function myself, but have been putting it to good use!
However, I'm committed to staying "old school" with my smilies... :-)
2016 T@B MAX S-aka: WolfT@B
Eric aka: Lone Wolf1 -
I have noticed the hyperlink feature seems to be a little wonky, particularly if you make a mistake and then try to edit it. In those cases I resort to just starting over.Verna said:...
I tried this same thing a dozen times yesterday and couldn’t get it to work. It worked the 4th time today!
I haven't really had the inclination to try and figure out its mysteries. It seems to work fine most of the time.2015 T@B Max S (320)
2015 Nissan Frontier SV V6 4x40
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
