newbie battery/charge questions
nolagringa
Member Posts: 25
Hi, I just bought my 2014 T@b and the sellers suggest keeping it plugged in all the time while stored in my carport.
Is that really necessary or beneficial?
Or if I'm planning to take it out once every month, could I just plug it in the day or two before a trip? (I'm in Louisiana so could feasibly use it year-round.)
If I'm boondocking and basically just using lights, will it last me 2-3 days without recharge? (Eventually I'll get solar and perhaps a generator, but not right away.) I saw someone put an on/off switch on the Jensen and I may borrow that idea. Besides the Jensen and the TV, are there other significant power drains to consider?
Thanks!
Thanks!
While not exactly your scenario, this thread may be helpful: http://tab-rv.vanillaforums.com/discussion/comment/24852#Comment_24852 (found by searching on vampire draw).John, Judi, Guinness & OD in PDX
T@Bit@t 2015 S Max Outback, ‘18 V6 4Runner1 -
And if the 2014 model didn't come with LED lights, your lights may use a lot of battery power. Many folks use rechargeable battery operated lamps for outdoor lighting and indoor too while boondocking.John, Judi, Guinness & OD in PDX
Thanks, @Twojgrams . I had searched and read for more than an hour and couldn't find as good of an answer as what you posted. @Michigan_Mike recommended plugging in "occasionally" for three solid days ... I wonder if this is once a month or so? That makes more sense to me than keeping it plugged in all the time, but my knowledge of batteries is limited.
I'm pretty sure they're LED lights. Agreed about the battery-operated lamps, ro a combination thereof. They're pretty nice lights so I want to use them sometimes.
You're so welcome. Solar powered lights like Luci lights are fun. You'll want something like this to check your charge. There are many different styles. https://tinyurl.com/y92qnmlw
Can be used in the 12V outlet in the tab and in your TV. My best advice is to read the Battery Information posted under the resources category. I dip in there periodically in the hope I'll understand it someday! And Fuses for Newbies is a fun read!John, Judi, Guinness & OD in PDX
Yes! I didnt even know such a thing existed - that's exactly what I need - thanks! I've read the fuses document at great length as I blew a fuse right away. Somehow I didn't see the battery information - will go back and look for it.
Those Luci lights are so cool!
Michigan_Mike mentioned this site on the Tag forum, may be TMI. http://batteryuniversity.com/learn/John, Judi, Guinness & OD in PDX
Nolagringa, do you have a battery cut off switch installed? If not, just pull the fuse at the battery. Either of these will eliminate phantom draw down of the battery. Depending on how discharged your battery is to start will determine how long it takes to recharge. The converter in the TaB charges slowly. You may be better served by hooking up a smart charger either continuously or in advance of a trip.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1
Thanks, @SAM ! I think that I do have an on-off switch but I have to double-check. From what I've read, I would like to not discharge below 50%, so I'll get one of those battery monitors to gauge until I get a sense of it. The seller also replaced the battery so I may want to upgrade it. The smart chargers look cool - so many things I didn't know existed before!
@Twojgrams - looks like some holiday reading - thanks!
@nolagringa, Either some good holiday reading, or a good start to a "wish" list for your T@B. Sounds like you're on your way to a lot better understanding of not only your new (to you) trailer, but your needs as well. If you haven't already checked, you might want to see what the AMP Hour rating is on your battery, it's also referred to as reserve capacity. If the previous owner replaced the battery, you might have an up-grade already.
2016 T@B MAX S-aka: WolfT@B
Eric aka: Lone Wolf0 -
@ericnliz - great, thanks, will check and see.
Hi Marie,nolagringa said:@Michigan_Mike recommended plugging in "occasionally" for three solid days ... I wonder if this is once a month or so? That makes more sense to me than keeping it plugged in all the time, but my knowledge of batteries is limited.
If you do have an "on/off switch" that allows you to isolate the battery from the trailer wiring you can plug your trailer in lets say, every one or two months and as needed to replenish the battery. Here in Michigan where the temperatures drop below freezing during the winter months, I normally give my batteries (on my lawn tractor, pontoon boat, T@B, etc.) a full charge in the fall and they remain this way until spring time with no issues. I don't unhook the batteries on my pontoon boat, the lawn tractor or my trailer and they survive the winter months. By giving them a full charge in the fall this minimizes any freeze up issues and this is something I have been doing for over 25 years now and with success.
On your T@B you could easily monitor the battery voltage occasionally (with the battery isolated from the trailer's electric circuits) and plug it in occasionally (every two months or as needed) for 2-3 days, check the voltage reading and you should be fine. If you have a wet cell style deep cycle battery you do need to check the water level and replenish any water lost via use/charging/heat, etc. with distilled water as this will help the battery maintain a good charge rate and extend the life of the battery as long as you keep the voltage level above 12 volts DC. I do use a battery tender (I have a couple here at the house) as needed as this floats the charge on my batteries and eliminates the need to constantly monitor and plug the trailer in to shore power.
And depending on how your trailer is wired and whether or not you do have an on/off switch for the battery you will want to verify the wiring (and the battery charge rate), as plugging the trailer in to shore power may not charge the battery if it is "completely isolated" via an on/off switch from the trailer's electrical circuit, so it's important to verify how the battery is wired into the trailer circuit, to measure the battery voltage when you are (a.) plugged into shore power (b.) unplugged from shore power (c.) and when using the on/off switch.
It is also important to note that after a battery has been fully charged and has been unplugged from a charger or lets say the trailer's electric converter, the voltage reading will tend to dissipate (lower) some and show a lower voltage read after 2-3 hours once the battery plates cool down some and the charge across the battery plates levels off. You will see this type of voltage fluctuation when using a solar panel to charge the battery or when you disconnect a solar panel from the battery charge port. This is a normal phenomena and is really nothing to worry about as this does happen.
And if you are not familiar with the way your trailer's electric circuits and battery are wired it is probably best to have a seasoned individual check these areas out for you, or take your trailer in to a nearby RV repair center and consult with them about the circuits (to verify the wiring) so that you are able to keep the battery charged and maintain it properly. Camping World techs normally will talk to you and may perform visual inspections & tests for you free of charge if you ask them beforehand. Most business people with integrity want to help others out without charging them a bundle, but on the flip side we have also seen where some entrepreneurs with less than honorable (and with unscrupulous) intentions did so in a manner that took advantage of people who were not knowledgeable in these areas.Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ1 -
@Michigan_Mike - thanks so much!
I'm also not a big fan of keeping my batteries on a charger full time. I give them a good charge when I put them away, then check them periodically with a multimeter and recharge as needed. How often that is depends on the age/heath of the battery, as weaker batteries will tend to not hold a full charge as long.
Also--just in case you don't already know--"50% of charge" is something like 12.1-12.2V. If it gets down to 6V, plan on shopping for a new battery!2015 T@B Max S (320)
2015 Nissan Frontier SV V6 4x45 -
Good to know - thanks, @ScottG !
