CoolCat AC and Refrigerator Power Draw
We do not have any paperwork or manuals for our 2008 T@B.  Need to know how many watts the CoolCat and Refrigerator draw running together.  Buying a small generator for when we camp on our remote property.  I have been told that the 2000w portables will not handle full load.
    EstancioEstancio Member Posts: 243
    I have the cool cat and the 2-way fridge but do not exactly know the exact electrical draw. As you noted, no paperwork came with my T@B either.  However I do know that a 15amp circuit in my garage will power up all AC units in my T@B. It has never tripped over many years of use. That translates to 1800 watts. General consensus seems to be that a 2000W generator will power the camper just fine.
    Stancil Campbell
    2011 T@B
    Rockingham, NC
    ScottGScottG Administrator Posts: 5,461
    Most appliances have a label on them that gives the power demand in watts or amps (from which you can calculate watts). Finding the the label could be a bit of of a challenge, but I'll bet a nickel it's there somewhere.
    Alternatively, if you can at least find a model number you might be able to hunt down the manual or specs online.
    2015 T@B S
    My brief online search yields this: CoolCat=1800W and Norcold 2way Fridge=100W.
    Thus 2000W generator should be fine.
    Stancil Campbell
    2011 T@B
    Rockingham, NC
    rfuss928rfuss928 Member Posts: 941
    edited January 2018
    The start up current for the CoolCat is too much for some 2KW generators.  The Honda and Yamaha models seem to be OK most of the time.   There was a lot of discussion of this on the Yahoo forum because DM T@Bs used CC ACs exclusively.
    I don't have any personal experience.
    bigskyboundbigskybound Member Posts: 16
    We ended up buying a 2800 watt Honda.  Will only use at remote property with camper or for home power outages.  So I tested it today and first a 20 AMP fuse in T@B blew when I put AC load on it.  Then I found that the generator's GFCI tripped.  Replaced fuse, reset GFCI and this time the fuse held, but GFCI tripped again. Had no problems when we hooked up to friend's 2000 watt Honda last year.  I also notice that neither of the AC Circuit Protectors on generator seem to reset.  Looks like I may have gotten a defective generator.
    Still, are there any tips to running camper AC, etc. off generator that I am missing?  Last year it was just plug n play!
    RatkityRatkity Member Posts: 3,770
    Do you know what a "loop-back" plug is?
    If you have external (or added) a Progressive-type surge protector, you'll need one. It has to do with floating grounds. Our engineer friends can elucidate more on these. You can either make one or Progressive Industries makes one.
    This *may* be your problem. Also make sure you aren't on Eco mode when you start up (you probably already know that). It's half the power sustained.
    Ratkity, I have no idea what a loop back plug is.  Please enlighten me.  Regarding the surge protector, is this similar to a surge protector power strip? Will either of these require a trip to "the shop" for installation or can  I simply get them from, say, CampingWorld?
    OK.  We found the surge protectors that can fit between power and camper without hard wiring.  Still scratching our heads about why this particular generator caused problems that the other did not.  Is it the inverter technology in the Honda EU2000?  I am completely at sea with electrical.
    edited July 2022
    All generators have inverters built in or there wouldn't be plugs :wink: V gave you a great link!
