Can you add a toilet and black tank to 06 Tab
FRANK
Member Posts: 9
Was wondering if it's possible to add a toilet and small black tank to already built Tab. I am purchasing a 06 Tab with all the upgrades even a porta potty. Would like to know if possible to add a permanent toilet and black tank. I don't need a wet bath just toilet since I am older the nighttime hassle. Thanks in advance
It might be better to just get a urinal:)Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1
From what I can tell from my 2015-S, the toilet and six-gallon black tank are an integrated unit that sit completely inside the camper.
While presumably doable, this would be an advanced DIY project. You would need to find an appropriate unit. Some carpentry work would be needed to prepare a suitable permanent location. The tank would need to drain through a large-diameter pipe that would have to pass through the floor and end in a dump valve outside the trailer. A water supply would need to be run to the toilet.
Sounds like a cool project, though. Please follow up if you decide to pursue this further!
The original idea for the T@B shower came from a Dutchmen owner that installed a Thetford Cassete toilet in the space where the front closet and CoolCat are located. If you don't have a CoolCat and are willing to remove the front closet. A Thetford cassete toilet will go in that space. It will require drilling a cutout in the sidewall for the cassette door. They you pull out the "cassette" tank and dump. I guess there would be a way to plumb the incoming water to your fresh water lines.Carol
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL2 -
Thanks I guess we will just use the porta potty its the same concept without the privacy. Good thing the wife and I became used to it from our pop up.1
Or, you could install a composting toilet.T@B 400 | F150 | Washington State1
- 9 “FOR SALE" - Camping & Trailer Gear
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
