ZAMP BATTERY CONECTOR.
Pinspot
Member Posts: 14
I just purchased a ZAMP 160 watt suitcase. My 2018 CS_S didn't come with an input in my front box. I was wondering if anyone knows what type of connector I will need to make it plug and play.
CES 2 Pin Quick Disconnect Wire Harness SAE Connector Bullet Lead Cable (16 AWG)
Coast
$6.99
Sent using Amazon Mobile for iPhoneDale Helman- Hash T@B Fun
You will need alligator clips to hook up directly to your battery.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Thanks guys. I was thinking there must be a bolt on connector that bolts to the tub/box. Apparently Nucamp stopped including them on the 2018 models. I have never actually seen one but have read here on the forum where they just plug right into the tub eliminating the need for alligator clips. I will keep searching and possibly contact Nucamp.0
Did NuCamp stop installing the ZAMP plug in the propane / battery tub?
Elsie at NuCamp can probably hook you up.
- Hash T@B Fun
Check with the Zamp folks to see if this sidewall port is what you need. I just bought a Zamp 120 watt suitcase and my 2017 Outback had a port that looks like this. https://backcountrysolar.com/products/zamp-sidewall-port There is some more info on the 160 watt page. https://backcountrysolar.com/collections/zamp-portable-solar-kits/products/zamp-160-watt-portable-solar-charging-systemDeb - 2017 T@B U-basic Outback silver/silver D@mselfly
2001 Toyota Tacoma 4WD New Mexico0 -
Thanks guys, that is exactly what I'm looking for. This forum works really well with knowledgeable people like yourself's.
A couple things to add, if they are not already obvious...
To use that plug you will need to extend the wire leads and install appropriate ring terminals to connect to your battery.
Check the polarity of your battery connections, and make sure they are matched to the leads coming from your controller. Zamp wires their SAE connectors opposite of other brands (like Battery Tender). This has created much confusion among neophyte solar installers. Just be sure to match + to + and - to - and you should be all set!
Another option: Battery Tender 081-0069-6 Ring Terminal Harness with Black Fused 2-Pin Quick Disconnect Plug https://www.amazon.com/dp/B000NCOKZQ/ref=cm_sw_r_cp_api_9z5VAbVSV4DT7
