Keder Rail length
Sharon_is_SAM
Member Posts: 10,034
Does anyone know off hand the keder rail length on the CS driver side? I am purchasing a shade cloth.
Sharon
Sharon
Thanks Manny! I hate having to store our Tab off site. Some day it will be housed with us. Sigh. I ordered an 8 x 10. That should stretch from the handle to the hinge of the hatch and shade the driver’s side and AC.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Smart idea @SAM! I'd be very lost if Bug was offsite and I couldn't go hide out, play with mods and daydream! How will you secure it out from your Tab?2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red0
@manny, I’m jealous, but it only hit 94 today in NE Ohio!😅. Ditto - stay inside.
@Homebodyatheart, the setup I ordered from Amazon comes with keder rail attachments with hooks (?correct size for the rail?), ball bungees, stakes, and grommets every 1.5 feet. We plan to attach it to the driver side keder rail and stake it to the ground 4 feet from the Tab using the stakes and cording as needed. The hypotenuse of the triangle was just over 8 feet, so I ordered an 8 x 10. It is good for 90% shade. Not only should it keep the driver side cooler/less hot, but, maybe the AC will run better. If we need more clearance for the AC, I have a tent pole/PVC apparatus that will elevate the shade cloth away from the AC. We’ll see how it works. We pick up the Tab Friday in preparation for some work at nuCamp and then on to uCamp.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1 -
"Hypotenuse" ... and no one ever thought that math was going to be necessary for fun things in life!!!SAM said:@manny, I’m jealous, but it only hit 94 today in NE Ohio!😅. Ditto - stay inside.
2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)2 -
@Ratkity, I could not figure out how big a shade we needed, so this worked! They even have an online calculator now,Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Ok, how about the slide rule. Now you’re talking!Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
My Dad used a slide rule until shortly before he was stricken with Alzheimers. My brother looked for and found Daddy’s slide rule, a prized possession because my brother still remembers how to use it, too!Verna, Columbus, IN
It's also good to have friends when you run out of fingers & toes!
2016 T@B MAX S-aka: WolfT@B
Eric aka: Lone Wolf1 -
Hey folks... I'm not THAT old and I had to learn to use a slide rule in high school!!!
2016 T@B CS-S silver with white trim and WSU themed
Pulled by a silver 2017 Chevy Silverado
Leaves on T@bventures from Spokane, WA
