T@b 400 door striker plate assembly question and shower leak issues
BigGrover
Member Posts: 450
Some of you may have seen my previous posting on my entry door problems. This weekend we used the camper and I noticed the striker plate assembly was loose. Just wondering if this might be part of the problem. There is a lot of wobble and I can move it side too side, up and down as well in and out 1/16th to 1/8th of an inch! Looks like screws that attach it to the door frame are backed out. Can any other 400 owners check theirs for this and let me know if it-s supposed to be loose? Also my shower leak has returned. A very slow leak after being connected to the external water supply water starts seeping out of the seam at the bottom of what I believe is the Alde cover. It is the white louvered panel under the shower faucet/ mixer valve. We had the fittings to the mixer valve fixed once already so I wonder if this is gonna be the Alde fittings this time.
BigGrover
2019 T@b 400 Boondock Lite
2018 Ram 1500 Quad Cab Hemi
Central Alabama
Central Alabama
My 400 striker plate assembly is tight.Jean & Arnie Nevada
2019 T@B 400 BL
2021 Toyota Sequoia 4WD -
@BigGrover are you using a water pressure regulator?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Thanks North and yes Sharon on the water pressure regulater. I even swapped it for a new one in case that was the problem.BigGrover
Central Alabama -
My latch is tight on my 400. I replaced the water lines with warranty replacements from NuCamp and that fixed the leaky shower. Very easy replacement with 4 screws holding the black
cover. 2018 T@b 400, 200ah Lithium with Solar
2013 Tundra TRD 5.7L
Massachusetts -
The dealership already did the leak repair once, said the fittings were bad. Don't know if it's gonna be the same thing this time.
BigGrover
Central Alabama
- 953 Air Conditioning & Refrigeration
- 919 Introductions
- 407 Service/Maintenance & Recall Notices
