3020HE PDF Manual
Thanks!Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Am I correct that the Compact 3020 replaced the Compact 3010? When did the change occur? What are the important differences?Thanks!2015 T@B Max S (320)
I think the 3020 has the high altitude feature built in. They started being installed in the ? late 2017 - early 2018 models, I believe.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
@ScottG - this from a post by MuttonChop December 2017
Alde 3020 available in U.S.
Dealer pasted on this bit of news from nuCamp.
Starting with December-2017 builds TAB's will be getting the Alde model 3020.
Alde 3020 has been available in Europe for a few years. One of it's features (as noted above) is a propane High Altitude operation mode.
I know of two differences in the 3020HE compared to 3010.1. High altitude mode which increases to internal combustion fan speed.2. Only one 'green case' Fuse. The ground side fuse is gone.Most likely other enhancements in the 3020HE which the two above are the most noticeable.
While over at the Alde U.S. site I noticed there is an update to the 3010 manual that I downloaded from the Manuals section here on the T@B Forum back in February.
https://www.alde.us/documents/3/v-3010-60-rev-1487-us-can.pdf
2016 T@B S - TV 2004 Toyota Sienna0 -
Woops - my bad - it's the same manual.2016 T@B S - TV 2004 Toyota Sienna0
Is the 3020HE the same as the 3020? My 320S has a 3020 without the HE addition2019 T@B 320 Boondock Edge0
vorticity said:Is the 3020HE the same as the 3020? My 320S has a 3020 without the HE additionBelieve the answer is YES. ALDE.us web-site quote:"In 2018, Alde's latest innovation in mobile heating arrives in North America. The Compact 3020 High Efficiency combination boiler, powering hydronic radiant heating and domestic hot water."
Adventures: 61 Nights: 417 Towing Miles 51,0500
