3020HE PDF Manual
Alde USA provided me with a North America version of the 3020HE User Manual.  They claim it is on the Alde site but all I could find were UK editions.
File attached . . . . maybe move to resources area?
    Thanks!
    ScottG Administrator Posts: 5,679
    Am I correct that the Compact 3020 replaced the Compact 3010? When did the change occur? What are the important differences?
    Thanks!
    I think the 3020 has the high altitude feature built in.  They started being installed in the ? late 2017 - early 2018 models, I believe.
    @ScottG - this from a post by MuttonChop December 2017
    Alde 3020 available in U.S.
    Dealer pasted on this bit of news from nuCamp.
    Starting with December-2017 builds TAB's will be getting the Alde model 3020.
    Alde 3020 has been available in Europe for a few years.  One of it's features (as noted above) is a propane High Altitude operation mode.
    MuttonChops Member Posts: 2,011
    I know of two differences in the 3020HE compared to 3010.
    1.  High altitude mode which increases to internal combustion fan speed.
    2.  Only one 'green case' Fuse.  The ground side fuse is gone.
    Most likely other enhancements in the 3020HE which the two above are the most noticeable.
  • rajamar
    rajamar Member Posts: 112
    While over at the Alde U.S. site I noticed there is an update to the 3010 manual that I downloaded from the Manuals section here on the T@B Forum back in February.
    https://www.alde.us/documents/3/v-3010-60-rev-1487-us-can.pdf
    2016 T@B S - TV 2004 Toyota Sienna
  • rajamar
    Woops - my bad - it's the same manual.
  • vorticity
    vorticity Member Posts: 14
    Is the 3020HE the same as the 3020?  My 320S has a 3020 without the HE addition
    2019 T@B 320 Boondock Edge
    Believe the answer is YESALDE.us web-site quote:
    "In 2018, Alde's latest innovation in mobile heating arrives in North America. The Compact 3020 High Efficiency combination boiler, powering hydronic radiant heating and domestic hot water."
