Leveling camper when boondocking
Trailpixie
Member Posts: 205
I’m just about to take possession of a t@b 320 Boondock. Yay!
i am planning to take it to a boondock site that isn’t perfectly level. I’ve been poking around for advice about setting up on irregular ground, and haven’t been able to find much. I went through “Post up some shots of your T@B set-up at the camp site!” thread and couldn’t find many examples of t@bs on anything but flat campground pads.
i did find the shot of @SkiCO site below on the following page: https://tab-rv.vanillacommunity.com/discussion/437/post-up-some-shots-of-your-t-b-set-up-at-the-camp-site/p34
This site setup seems to be a very inventive setup and much like the setup I’ll be needing. But, I want some opinions and advice about a few things. Before I dive in, I’m sorry @SkiCO if I’m being too critical. First, I’m sure he would have preferred not to use rocks on the front stabilizer, but I think my biggest concern would be with leaving the wheel on the jack. That seems to be a weak point.
as for the height of the setup, all the other points are nicely lifted with leveling thingies (those LEGO-like stackable things). The stabilizers are all down and would add a lot of stability, making the whole setup pretty stable.
So, if I setup my camp just like this, and replaced the rocks with levelers and took the wheel off the jack and put a block of wood on top of those levelers, would you folks consider this a safe setup? Could the lower side go higher? How high could the jack go without goin crazy (how many inches of levelers could I put beneath a fully raised jack)? I don’t see any wheel chocks. Is that a problem with all the stabilizers deployed?
(Somewhere I saw a pic of a very extreme use of levelers, but I can’t find it right now. For the sake of discussion, can anyone find it?)
thanks, @SkiCO for being my guinea pig.
(previous 2018 T@B 320 Outback, 2021 Jeep Grand Cherokee V6)
Maryland
Looks a bit dangerous to me without chocks. It's this kind of situation that prompted me to bring home a 10ft 2x8 and cut it into 2ft lengths, so I can stack them and still have room for chocks around the wheel. The jacks I installed on the back let me lift the wheel off the ground to slide the blocks under.-Brian in Chester, Virginia
Look at a BAL Leveler. It will lift the low side a pretty good distance, then you can save the waffle blocks for putting under your stablizers and front wheel. You can replace your style wheel with a flat foot if desired.
Carol
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL2 -
Depending on how rocky the ground is, digging a hole to lower the high side works to within reason, obviously you don't want and part other than the tire on the ground.2019 T@B 400 Boondock Lite0
I've used a BAL leveler at one spot and had to lift one side of the trailer almost a foot. I also had to use a nice flat rock to "stabilize" one stabilizer. I always leave me wheel on the jack, I've never thought of taking it off when parked.I agree with the chocks, though. The BAL works as a chock, but I would still chock the offside wheel.
Will will the BAL leveler work on rocky or uneven ground?
(previous 2018 T@B 320 Outback, 2021 Jeep Grand Cherokee V6)Maryland
When I had to lift that one side, it was in the desert in California, and the site was mostly gravel. The surface didn't have lot of holes, etc, it was just on a strong slope. Check the videos on the BAL: it really slides on the surface on two "pipes". The pipes might catch on some stones/gravel/grass as you try to slide it around the tire. I carry a small trowel if I need to dig around or repair an uneven surface like that.
We leave our wheel on the jack almost always. There are dish-like pads designed to keep it from rolling. Sometimes you need that height of that wheel with the jack.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1
