Vodka is not the answer
jkjenn
Member Posts: 6,425
I realize those in mild climates have a lot of fun posting photos and joking about winterizing with vodka, but it should be done so, cautiously. It is a novelty. I get it.
Vodka can freeze at temperatures as high as -7F, so this is not a good idea in cold climates. It is not unusual to get below that temperature north if the Mason-Dixon Line. Second, rv antifreeze is non-toxic, odorless, and tasteless. Third, rv antifreeze is pink and a visible reminder that you need to dewinterize in the spring.
Feel free to use vodka if you like, but please do not recommend that everyone use as it is not suitable for cold climates.
3
JK, it depends on the question!2015 Max S Outback | 2010 Xterra -- Retired
2022 Ford F350 Tremor | 2022 Cirrus 6203 -
My thoughts exactly...Terry & Jody... 2025 Honda Ridgeline RTL
2016 NuCamp 320 T@B Max S
T@bbey Road
Appleton, WI0 -
Gin.John, Judi, Guinness & OD in PDX
My nephew introduced me to a chocolatini (OMG!) this summer, used vanilla vodka. First time I’ve ever liked the stuff!
2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red0 -
Vodka may not be the answer, but it will help you forget the question. ;-)
2015 Nissan Frontier SV V6 4x49 -
Seems like alcohol abuse to me!
John
2007 T@B
Rockford, IL
Just imagine how much fun de-winterizing would be. Get a glass with some ice, turn on the pump, open a faucet, have a party. Grey Goose shower? Oh my
2017 T@B 320S 2019 Jeep Cherokee - Southern Connecticut1 -
That all depends on what it is you're trying to winterize. Just ask Vladimir and Viktor!
John & Lori in Northern VA
Former owner of 2015 T@B CS Max "Uteki" aka "H@wk T@B"
2012 Toyota Tacoma Double Cab 4x4 Off-Road "Zame"3 -
I’ll take Arizona and a good Margarita any day!
As for winterizing, I prefer to blow the lines out with air, empty the pump and add in the pink RV antifreeze to my sink, shower and toilet areas. If I were staying in Michigan through the winter I would also empty out the gallon of RV antifreeze added (2 gallons total) to the gray and black tanks, place a screen over the outlet where both dump from (to keep critters out) and leave both valves open. This allows both tanks to dry out. I’ve done this before per instructions from a dealer and never had any issues.Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ4 -
The hard part is waiting till next spring. I prefer gin and tonics with a cucumber ice cube!
2007 T@B
Rockford, IL
