Alde exterior vent screen prevents mud dauber and wasps
GrayGhost
Member Posts: 23
The T@B 400 manual says to "Cover exterior vents" for storage.
Has anyone made a mod(cover) for the Alde exterior vent?
Thanks!
Yes, I made a little bowl-shaped cover out of ¼"-mesh "hardware cloth" (actually might be ⅛"-mesh), that I screw onto the vent during mud-dauber season, when the Alde isn't being used.
It's a good idea to cover any vents (incl. fridge) if you have mud-dauber wasps in your area! I've also covered all drain tubes that way.
Chan - near Buffalo NY
A_Little_T@b'll_Do_Ya1 -
Thank you ChanW. We have mud daubers here in SC
I have a screen permanently installed - Camco 42150Drilled a couple of tiny holes in the plastic vent to install with wire.
Reformed tent campers now in Ab T@B - 2016 Outback1 -
Thank you SteveW
Also see Alde notes to be careful about getting water in the vent when cleaning the T@B.
2018 T@B 400, 2017 Nissan Titan Crew cab1 -
Got any pictures of your installation? The screen you linked to is square, but my Alde vent is round so I'm a bit confused.SteveW said:I have a screen permanently installed - Camco 42150Drilled a couple of tiny holes in the plastic vent to install with wire.
The capacity to learn is a gift; The ability to learn is a skill; The willingness to learn is a choice. | -REBEC OF GINAZ2019 T@B 320S BD Lite, Jeep TJUR, Jeep JT0 -
Looks good!
@targ, TBH I never run the Alde with the screen in place. I'm concerned about limiting the airflow, with the Alde's sensitivity to air/fuel mixture ratio - high altitude problems.
I always remove it when in use, and usually only have it on during dauber and lady-bug nesting season...Chan - near Buffalo NY
I can't imagine the airflow being significantly altered - that's a pretty coarse mesh. But, the Alde exhaust is rather hot so that could be an issue if someone got a hand on it while the Alde was running on propane.If/when I get around to doing this, I may just run the Alde with it on and check the temp on the mesh to see how hot it gets.Do you also cover the various other vents?The capacity to learn is a gift; The ability to learn is a skill; The willingness to learn is a choice. | -REBEC OF GINAZ2019 T@B 320S BD Lite, Jeep TJUR, Jeep JT1
Thanks for these tips on the Alde vent screen. While ordering one, I also ordered this item for the frig vents..
Camco 42156 Flying Insect Screen for Norcold Refrigerator Vent https://www.amazon.com/dp/B01J6DMJ0U
And one of these to replace the duct tape that's been holding on one end of a frig vent after I broke one of the clips..
Norcold 617772 Replacement Latch https://www.amazon.com/dp/B00CBZ3ST2
No more worrying about the critters! Thanks again.-Brian in Chester, Virginia
@targ, Yes, I covered all the vents and drain tubes that might be attractive to a mud dauber. We also have covers over the three way fridge intake/exhaust vents when we aren't using it.
I didn't screen the main drains for the water lines, not sure why, but they'd be easy to clear if they got plugged.Chan - near Buffalo NY
A_Little_T@b'll_Do_Ya0 -
Another thing to note about the Alde, is that it creates moisture with its exhaust. This will matter in winter camping, because you'll have an icicle hanging from the exhaust vent.
I think having a screen on it while winter camping could create an ice dam.targ said:I can't imagine the airflow being significantly altered - that's a pretty coarse mesh. But, the Alde exhaust is rather hot so that could be an issue if someone got a hand on it while the Alde was running on propane.If/when I get around to doing this, I may just run the Alde with it on and check the temp on the mesh to see how hot it gets.....
I was also wondering about the best way to permanently block insects from getting inside the plumbing vent located on the drivers side near the front corner.-Brian in Chester, Virginia
@BrianZ, I think if you remove the plastic vent cover you can place some screening over the opening then replace the cover. I know @Dalehelman changed his vent, so I know thecover can be removed/replaced.
Check this out. https://tab-rv.vanillacommunity.com/discussion/4535/how-i-flush-my-black-water-tankSharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1 -
I bought the 4 inch square bug screen and when I went to put it on out came the wasps! I suggest you all get the screen! Art2019 TaB 320 S Boondock Edge0
