How I flush my black water tank
Dalehelman
Member Posts: 2,414
While working on another idea involving the black / gray water vent system. It occurred to me that by placing a hose into the vent pipe I can fill the waste tanks from outside the trailer. This makes flushing those tanks simple and easy. I simply replaced the stock vent cover with an outdoor double outlet cover. That way I now have access to the vent pipe.
- Hash T@B Fun
Does it vent when the door is closed?0
Yes the door does not have an air tight seal and there is silicone around pipe itself.
- Hash T@B Fun
Now that is interesting.
It is interesting. So physics peeps, does that mean the gasses have an opportunity of going upwards and away instead of accumulating under the "bell" and then making their escape?2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)0
????Ratkity said:It is interesting. So physics peeps, does that mean the gasses have an opportunity of going upwards and away instead of accumulating under the "bell" and then making their escape?- Hash T@B Fun
Ratkitty, even with the original bell over the vent pipe, gases will push forward and escape. I think having the outlet at the bottom, rather than the top prevents rain/ water from entering the vent. I think the vent pipes are importantly for the purpose of allowing air to enter and prevent a vacuum. I suspect there may be a concern if water accumulates in that pipe - tanks will not drain.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1
FLUSH! 2016 T@B MAX S-aka: WolfT@B
Eric aka: Lone Wolf0 -
Oh... of course about the vacuum. ScottG had the schematics of the black and gray tank venting pipes using that single outlet/inlet. If the pipe is too long and butting against the bell, there'd still be enough opening for air exchange to prevent a vacuum, but perhaps some extra collection is happening for Dale? It was just a thought (pre-caffeine).SAM said:Ratkitty, even with the original bell over the vent pipe, gases will push forward and escape. I think having the outlet at the bottom, rather than the top prevents rain/ water from entering the vent. I think the vent pipes are importantly for the purpose of allowing air to enter and prevent a vacuum. I suspect there may be a concern if water accumulates in that pipe - tanks will not drain.2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)0 -
@Ratkity, put on some rubber gloves, take a cheap soft bristled brush and brush the soot off your Little Campfire logs. It quick, simple and has great results.Verna, Columbus, IN
Gloves are a must! I used an old toothbrush. The soot just flaked right off (careful of wind direction too lol). The vermiculite idea is good because it doesn't soot, but I'd be afraid it would dump out accidentally and get everywhere.Verna said:@Ratkity, put on some rubber gloves, take a cheap soft bristled brush and brush the soot off your Little Campfire logs. It quick, simple and has great results.2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)1 -
Yep, that is correct. Waste vents serve the dual purpose of allowing stinky gases to get out, and allowing air to get in so that the draining of fixtures isn't impeded by a vacuum in the pipe.SAM said:Ratkitty, even with the original bell over the vent pipe, gases will push forward and escape. I think having the outlet at the bottom, rather than the top prevents rain/ water from entering the vent. I think the vent pipes are importantly for the purpose of allowing air to enter and prevent a vacuum. I suspect there may be a concern if water accumulates in that pipe - tanks will not drain.
It's unlikely enough water could accumulate in the pipe to actually block it, but it would flow into your holding tanks and fill them up faster. (This is not a concern in house plumbing, as any rain water that gets in the vent just continues out to the sewer or septic tank.)
Ratkity my concern with vermiculite is that I believe it is a known carcinogen (the dust I think), and heating it might make things worse. Just a thought. My preference would be lava rocks or some kind of stones like river rocks.2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red0
@Dalehelman, just curious, if the pipe has double use for gray and black, how do you know you are flushing the correct tank? Perhaps you know the amount of fluid that should be flushing out of the black gate valve when it's open and watch the clean out. I have one of the clear attachments elbows with the hose connect and valve to flush the tanks. I like that I can see when the water is clear when I'm done cleaning.2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)0
While adding water through the vent water can flow into both tanks primarily the black. I also use a clear elbow at the discharge point. I close gate valves for a minute to allow tank to partially fill then flush. The best part is I can flush standing up.
- Hash T@B Fun
I'm sorry @Dalehelman!! All I could think of was an RV potty that has a foot pedal to flush it.Dalehelman said:...
@Dalehelman, I mainly just wanted to thank you for this great idea. Like many of your mods, this makes life easier with minimal effort to get installed.
Question: I thought the idea of flushing the waste tanks was something one would do after emptying them at the dump station; however, in your last photo it appears you have the water line also connected to your city water inlet. Why?
Comment: Regarding @Ratkity's question, it seems to me that based on photos of the plumbing in factory photos of partially built T@Bs, one might be able to select the tank to be filled by pushing the fill hose at least 3 ft into the pipe to deliver water to the gray tank, or only a foot or so to deliver water to both or mainly to the black tank, depending on water pressure.-Brian in Chester, Virginia
Oh! Ok, now it makes sense. Thanks.
I have only heard of "full hookups", but have never seen them. I don't know if they even exist anywhere here in Virginia.
We were at Swallow Falls SP in western Md. and was surprised they had full hook ups. Also, I recall staying at a “mom &pop” campground outside Shenandoah, near Elkton that had full hook ups...so...there out there, though I stumble on them rather then seek them out...BrianZ said:Oh! Ok, now it makes sense. Thanks.
I have only heard of "full hookups", but have never seen them. I don't know if they even exist anywhere here in Virginia.TV- '16 Chevy Colorado LT Crew Cab-DuraMax
2018 320S Outback0 -
So @Dalehelman challenged me to mod his mod. So I did. This piece of pipe insulation stops backflow from the hose, is about 2” long and just glued in.
2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red1 -
Great Idea!!Any issue with water backing up into sink or shower drain? I don't know how the venting is plumbed for the tanks. Is there a vent diagram posted somewhere? I've also seen these wands you stick down the toilet with a right-angle spray fitting to clean out the black tank. Ever use one??2022 T@B 320S Boondock0
I did use a wand when I was at home. Because it does give a much better Rinsing of the tank. Using the vent pipe is just quicker and easier at a dump site.
- Hash T@B Fun
thanks for info. Is that vent for black tank only?
2022 T@B 320S Boondock0 -
No it vents no it vents both gray and black. Most of the water will end up in the black tank
- Hash T@B Fun
@stepheng, there's a plumbing schematic posted in the "Users Manuals..." category.
The vent line drops (more or less) directly into the black tank. The gray tank is vented via the sink drain, which tees off the main vent line. That's why most of the water ends up in the black tank.
2015 Nissan Frontier SV V6 4x40
