Look what followed me home Saturday!! Should I use less drop in the hitch?
lkc001
Member Posts: 881
Hello all--So that followed my truck home Saturday! woohooo!!
Full propane bottle, battery & tire on the front. My TV still has @ 300 lbs of sandbags over the axle in the bed. Trailer of course not loaded. With the 2" drop hitch it looked pretty level, maybe slightly low in the front, pulled good. A tiny bit bouncy where they were doing construction on the road/detour, but again, trailer was not loaded. However, as I commented in another post, I scraped the wheel crank post backing into my sloped driveway at the curb and had to fight to get the wheel on once on the level part of my driveway. Should I put on my straight hitch next time when I am fully loaded & ready to camp? I'm also looking at other wheel jack options too. Just wondering about others' opinions?
Full propane bottle, battery & tire on the front. My TV still has @ 300 lbs of sandbags over the axle in the bed. Trailer of course not loaded. With the 2" drop hitch it looked pretty level, maybe slightly low in the front, pulled good. A tiny bit bouncy where they were doing construction on the road/detour, but again, trailer was not loaded. However, as I commented in another post, I scraped the wheel crank post backing into my sloped driveway at the curb and had to fight to get the wheel on once on the level part of my driveway. Should I put on my straight hitch next time when I am fully loaded & ready to camp? I'm also looking at other wheel jack options too. Just wondering about others' opinions? 2018 Tab 400
How do I add a picture??2018 Tab 400
@lkc001, size picture to 600 x 800 or 800 x 600 pixels. Just above comment box, click on picture icon. It looks like a mountain in a box. Select your pic from gallery or photo library. It will load into the comment box and then you post it as you would post a comment. Good luck, as I'd love to see the pics, and I'm sure others would too!2017 t@b sofitel(Dr@gonsFly)TV 2015 Silverado 2500hd(Behemoth). Wyandotte, Michigan.
@lkc001 This thread may be useful for learning to post pics. Goes through a number of troubleshooting steps. https://tab-rv.vanillacommunity.com/discussion/7989/how-do-i-post-pics2019 320s BD Lite, white with blue (“Haven”)
Pacific NW0 -
2018 Tab 400
2016 Nissan Frontier SV 4x4 Crew Cab4 -
Hope I did that correctly.2018 Tab 400
@lkc001, yes we can see your pic now. Nice!2017 t@b sofitel(Dr@gonsFly)TV 2015 Silverado 2500hd(Behemoth). Wyandotte, Michigan.
Your drop is likely fine. When you lose the winter ballast in the bed it will come up some. I have the same set up. Congratulations and enjoy.
@IKC001. I did have the problem of occasionally scraping the hitch on steep driveway approaches, but that was with a 5 inch drop. Haven’t had a problem with the 2 inch. However my trailer is a Outback edition and therefore is lifted. If your trailer nose is a full bubble low try flipping your ballmount and resting the hitch on the thread side of the ball if it’s level then swap the ball around if it is. Or start a collection of ball mounts 😀. You’re better off slightly low than high. I have also added Sumo Springs on the back of the Frontier to reduce the saggy rear 😳, I know TMI.Norm & Pat. 320 S Outback Utah or somewhere else.
Nice! I have similar, a Nissan Frontier with the offroad package, and a 2004 T@B. They seem very well matched.2004 Dutchmen T@B T2 (fiberglass!)0
We can’t have any saggy rears either LOL2018 Tab 400
I would suggest Firestone air bags for the rear of your truck. Very easy to install. They will level you and and eliminate the bounce. I also would suggest the “Jack-E-Up” add on that allows you to remove your jack and store it on the frame when you are traveling and as you are backing it into a camp site or your steep driveway it won’t scrape.Tow with a 2016 Tacoma TRD Sport, 2016 T@B CS-S Max
@lkc001, I also tow a standard 320 with a Frontier. I have the Nissan OEM tow package that came with what I believe is a 4" drop ball mount. My T@B tows almost perfectly level and there is very little sag in the rear of the truck even with cap, kayaks, bikes, etc. loaded in the back.Yours does look a little droopy in the photo; it could be perspective, though I suspect the winter ballast you had back there contributes as well.2015 T@B Max S (320)
Thank you all for the great info!2018 Tab 400
When the sand bags are removed you will know a lot more. Check out the “Jack-E-Up”. It’s a great way to remove the jack from danger and gives you more room to access the bed of the truck or bring bikes.Tow with a 2016 Tacoma TRD Sport, 2016 T@B CS-S Max
This is with the Jack-E-Up on the trailer with my bike
I do not believe that the jack-e-up will be a solution for me, unfortunately. I have the spare on the tongue mounted to the jack post.2018 Tab 400
Change to side mounted spare?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
As an alternative toSomo Springs, look at Timbren SES system to help with rear end sag. Simple to install and need no inflating and never go flat. Use them on our 2016 Frontier crew cab with our 400. Look at Etrailer.com
2018 T@B 400, 2017 Nissan Titan Crew cab0 -
No I have enough issues with my sloped driveway at the street— don’t need anything else hanging down low2018 Tab 400
