Wobbly loose Lagun
Kat1tulsa
Member Posts: 11
We bought an used 2017 320S and the table top slants down and it seems like someone pushed down on the end making the joint loose. I have not found a way to fix this. Anyone else have this issue?
How about a picture? Has the plate that holds the table top come loose or is the problem with the ratchet handles?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Here are pics0
Ok, you need to loosen the ratchet handle in the picture and let the support arm peg enter fully into the opening. You should not be able to see the peg.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1
@Kat1tulsa, please resize your photos. https://tab-rv.vanillacommunity.com/discussion/47/what-size-should-my-posted-forum-photos-be#latestSharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1
Thank you!!!! That was it!0
