Adding a bathroom Porthole window to a 320s ?
2»
    The earlier NuCamp porthole windows have an aluminum frame and are slightly smaller in diameter. The newer style is all plastic. I am not sure when they changed. Around year 16-17 I believe. When we installed the bath one we replaced both so they would match. The rotating shade is also slightly smaller on the early version.
    1. Hash  T@B Fun
  • rfuss928rfuss928 Member Posts: 1,136
    edited August 2019
    Both of the portholes in our T@B have a one piece rubber seal.
    Here is the inside view of the ~13 inch window
  • teztabteztab Member Posts: 99
    teztab said:
      I still have the rotating blind to fit, but rather than adhering that permanently, I plan to use small velcro pads so it can be removed for wiping and cleaning.   Feeling very pleased with this easy upgrade!
    In my earlier posting, within this thread, on installing a bathroom window, I mentioned I was planning to fit the rotating blind with velcro tabs. So, having purchased the velcro, I discovered NuCamp already had the same idea - the adhesive pads on the screen ARE velcro!  Should make it easy to remove for wiping and cleaning...
