Homemade Exterior Window Shade Ideas
KatieMae
Member Posts: 13
I see there are a few ideas out there for exterior window shades. I am planning on sewing my own out of sunbrella fabric, and using a lighter weight interior blackout curtain fabric liner.
The question: Has anyone tried or thought of using a piece of elastic around the edge to hold in place ?? One might only be able to use elastic on 3 sides due to the hinge at the top of the window.
Anyone have ideas or suggestions before I go to cutting fabric ??
KatieMae - 2010 Toyota Tundra, 2018 T@B 320S Outback
I made window covers from fabric based on the patterns here in the files. I believe they make a huge difference in the amount of heat that comes in when the sun is directly on any given window
2018 Tab 400
@KatieMae, there are easy patterns already posted and linked here on the forum. Some are even reversible. The pattern calls for a pocket to hold the bottom of the window and an elastic band nearly midway up the window to hold the curtain/cover in place. They are used for shade, privacy and style when camping with open windows. I think the pattern calls for 2/12 yards of fabric to cover all three windows. There are pics posted here too. If you need more inspiration, there are t@b window covers listed on the ETSY site. -Denise.2017 t@b sofitel(Dr@gonsFly)TV 2015 Silverado 2500hd(Behemoth). Wyandotte, Michigan.
I have some that have a piece of elastic that slips over the top 2 corners. The first link below has the original instructions.
https://us.v-cdn.net/5021717/uploads/FileUpload/7c/217967229dd8938d955b7565a0a14e.pdf
https://tab-rv.vanillacommunity.com/discussion/429/window-awning-covers-shades
Here's what I did..
https://tabforum.nucamprv.com/#/discussion/6995/window-awning-design-clip
It has never been windy enough for us to need the plastic clips, so we haven't used them yet. The pocket at bottom edge & elastic going across the top corners is all we've ever needed & they are easy to put on & take off.-Brian in Chester, Virginia
Thanks ALL !! Some good ideas. I did see the discussion about the curtain patterns with the velcro straps; I might add with super great photos and instructions. I don't see any need for the scalloped edges though.Is the overhanging edge of fabric necessary to shed rainfall?? Or purely decorative?I just wondered about a long perimeter piece of elastic, sewn around the edge in it's own 'pocket edge', to hold in place. I envision a large lined rectangle, with elastic edges. Might hold well in windy situations too. I already have the fabric, and light weight blackout liner. I thought the liner might help insulate against the heat, but also in a campground with intrusive streetlights, when one wants to leave the window open.I might just have to make one and see how it works.KatieMae - 2010 Toyota Tundra, 2018 T@B 320S Outback0
Try it and let us know. The only negative I can see is it may have a gathered look around the edges.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Aside from being decorative, I don't think the hanging edge is necessary, but it can be functional in providing a bit of additional privacy when the window is more open.KatieMae said:...Is the overhanging edge of fabric necessary to shed rainfall?? Or purely decorative?I just wondered about a long perimeter piece of elastic, sewn around the edge in it's own 'pocket edge', to hold in place. I envision a large lined rectangle, with elastic edges.
...I might just have to make one and see how it works.
I think your idea of an wide elastic band pocket around 3 sides sounds very feasible & worth trying. It could eliminate the need for a diagonal strap across the top corners.-Brian in Chester, Virginia
RV: 2018 T@B 320S, >100 mods1 -
I had fishing weights put into the two lower corners of the shades. Works great keeping them from flipping up in the wind.2016 Outback 320
Thanks once again for your comments! Yes, the extra fabric on the lower edge would provide additional privacy, and the opposite would also apply. It would limit visibility. Guess I need to determine my priorities. Eh?About time to start sewing. I do have extra fabric if it doesn't work out.KatieMae - 2010 Toyota Tundra, 2018 T@B 320S Outback0
I just bought a 9.5 x9.5 waterproof Sun Shade Sail Canopy on Amazon with a set of extending tent poles that extent to 8.2 feet. I'm planing on buying the Keder Awning Rope to sew onto it to slide into the keder rail on my 2016 Tab max CS-S Clamshell. I use a tailgate tent over the kitchen which works great. I hope this helps with a DIY idea.1
