I see there are a few ideas out there for exterior window shades. I am planning on sewing my own out of sunbrella fabric, and using a lighter weight interior blackout curtain fabric liner.
The question: Has anyone tried or thought of using a piece of elastic around the edge to hold in place ?? One might only be able to use elastic on 3 sides due to the hinge at the top of the window.
Anyone have ideas or suggestions before I go to cutting fabric ??
Finally! New Owner of a 2017 Tab 320S!
Woohoo!
https://us.v-cdn.net/5021717/uploads/FileUpload/7c/217967229dd8938d955b7565a0a14e.pdf
https://tab-rv.vanillacommunity.com/discussion/429/window-awning-covers-shades
https://tabforum.nucamprv.com/#/discussion/6995/window-awning-design-clip
It has never been windy enough for us to need the plastic clips, so we haven't used them yet. The pocket at bottom edge & elastic going across the top corners is all we've ever needed & they are easy to put on & take off.
I think your idea of an wide elastic band pocket around 3 sides sounds very feasible & worth trying. It could eliminate the need for a diagonal strap across the top corners.
