Sewer hose storage on T@B Outback
2»
    What a great location, albeit more work is required to configure.  Does this location impede the venting of any propane fumes that may accumulate at the bottom of the tub?
  • plicatoplicato Member Posts: 12
    This worked for me.
    Hi Dale,
    What is the brand of your sewer hose storage unit? When you mentioned that is it is affixed to the T@B with 4 bolts and fender washers, did that involve drilling? Can you please elaborate on how it’s attached?
    Thanks so much! I really like your custom upgrades!
    Paul
    2018 T@B 320 S, 2014 Subaru Outback 3.6R Limited
    edited August 2018
    @plicato
    The tube is drain pipe from Home Depot. Bolted through the rear pan. Four 1/4” bolts with fender washers. Inside the tub is a 6’ x1” piece of aluminum for extra support. Also from HD .
    1. Hash  T@B Fun
  • SueBCSueBC Member Posts: 70
    edited August 2018
    SkiCO said:
    Just mounted my hose storage on our new Outback.  I like this because it was really easy and did not require any permanent modification.
    I like your idea - I too am in the same situation with my Boondock. - So you just used the straps (2) to tie onto the rack? - and as you posted in 2017 - how is it holding up? did it slip at all (with only two straps)? Also guessing this is a 64 inch tube? - although on second look it looks shorter than a 64 inch tube.
    SueBC
    British Columbia, Canada
    edited August 2018
    Ah - been looking online and Valterra has an adjustable hose 34/60. I think I might go with that one as the 64 inch may be too long to hold with the straps in the centre area of the Yakima. I do like this set up for the Boondock and think its a great alternative to the front tongue. Also the 15 ft Rhinoflex looks like it will fit, as someone says it collapses to 56 inches. Thanks for sharing the photo's - shows newbie me how its set up.
    SueBC
    edited August 2018
    So - I decided to go white, and have three straps. If one strap fails, the other two would be able to keep it on. Also - as I purchased the adjustable carrier, but want it kept at 60 inches, I glued it at the joint to stop any movement. No holes drilled in the T@B - I'm against doing that.
    SueBC
    Looks good!
    @SueB, white was a good choice.  Camouflaged against the white TaB.
