Repainting T@B trim
mazamabill
Member Posts: 2
I purchased a 2014 T@B Max S last year. Unfortunately, it is a model that is all gray, including the trim. I much prefer the look with the different colored trim. Does anyone have experience repainting the trim? Any advice is welcome. Thx. Bill
I just took mine off & repainted all the trim. Its easy, but time consuming. Mine was an older 2005 model so I'm glad that I did it. The plastic was starting to break & crack. I reinforced the some of the pieced with with aluminum flashing & JB Weld on the underside to stop the cracks & breaks.2005 T@B Dutchman
When I bought my T@B in January the trim was red. I wanted it silver for the design I was adding. I regret that decision. It is chipping everywhere - from rocks or even small bumps into it. In hindsight, I would have ordered new parts from NuCamp instead. The price would probably have been the same, as I paid $1500 to have it painted. Looking at the pics I kind of miss the little red guy!
That is good to know as I have also considered repainting the trim. BTW I love your design. Is it decals?
I repainted my Red Clamshell trim myself back in 2007. Navy Blue. I only have the windows, fenders and front handle trim. I used spray paint for plastic. I pulled it all off again in 2014 and repainted. It has held up well.Carol
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL -
Did you have issues with replacing the trim and having water enter the screw holes? I've been warned that is an issue.
I use silicone caulk on the holes when I reinstall the trim.Lesley_and_Ian said:Did you have issues with replacing the trim and having water enter the screw holes? I've been warned that is an issue.2005 T@B Dutchman -
I have a roll of the sticky stuff and I make sure I put fresh sticky over each hole.
(I forget the name of it)Carol
MOUSE-KE-T@B
Harvest, AL -
Oh and just an FYI, the first time I pulled the trim off, I found a couple of "oops" holes under the trim. I filled those with silicone.Carol
MOUSE-KE-T@B
Harvest, AL -
Here are my before & after pics. (Bottom pic is the Before pic)
I went with the original yellow & repainted the grey plastic a dark regal blue.
I also reinforced/repaired the trim with aluminum sheeting & JBWeld.
I used washers with neoprene gaskets when replacing the screws,
2005 T@B Dutchman -
Great job!
Hello! I’m new to this site. I just bought an all white 2016 T@b. I’d love to paint some of the trim. What type of paint should I use?
Check out Krylon brand.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
I started off with Krylon, but then they changed their formula halfway through my paint job. The new formula had the same color names, but the finish & color was off and I didnt like it so I switched to a Rustoleum color that I like. I basically primed with Krylon & used Rustoleum as my Finish coat.2005 T@B Dutchman
- 916 Introductions
- 72 Teardrop Groups & Links
