Cat door to wet bath in T@B 400
Jilong
Member Posts: 87
When my wife and I go traveling, we always bring our cats (actually one of the reasons we bought the T@B 400 to travel around the country). We keep the litter box in the wet bath so it's out of the way, but we hate propping the door open all day just for the cats -- it significantly narrows the hallway and makes it harder for the humans to move around. We decided a cat door would be perfect.
I searched the forums for an existing modification to add a cat door to the wet bath but didn't find anything, so my wife suggested making a corner cat door to keep the design simple. I cut the bottom right corner off of the door at 12" on each side and added two small hinges and some magnetic latches to keep it opened and closed. That door size works well for our two small-medium cats (9 lbs.).
For the most part, we keep the cat door open and only close it for privacy when using the toilet or the shower.
2018 Tab 400 × 2013 Toyota Highlander Limited AWD
13
This is an original. Very clever! And no real functional harm done to the door.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1
Hilarious Clever and Wondeful! Great work!2019 Custom T@B 320 U Boondock Lite-ish
We've slept in 34 states, 2 countries & counting0 -
Looks like the cat's meow!
2 -
You can always re-install a new door from the factory if you ever sell the trailer in the future. Great work around mod for sure!Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ1
Oh my what a great solution!! We also have a T@B 400 and thought of taking our elderly cat named The Tuna with us. He is a rather big cat and requires a large litter box. It might be hard stepping over it to use the adult toilet in the middle of the night. Do . you have to move the litter box if you use the human litter box???
Pam and Ron, 2018 T@B 400 named Felix, white with black trim, pulled by a 6 cylinder Toyota Truck.1 -
We use the Litter Locker, which is a one piece, flexible litter box with two handles that can be brought together at the top and lifted out with one hand.
https://www.petsmart.ca/cat/litter-and-waste-disposal/litter-boxes/litterlocker-litter-box-with-scoop-5279407.html
It's nice because it has really high sides but it's still small enough that we can usually step around it, but lifting it out is still very easy with just one hand.
I'm not sure why it's so hard to find it in the US, probably because there is another product with the same name that is not a litter box at all. The link I gave above is to a Canadian PetSmart, but we bought ours at the local pet supply store.2018 Tab 400 × 2013 Toyota Highlander Limited AWD1 -
@ Jilong Looks like a Birman...2019 T@B 400 -- 2017 Toyota Tundra
South Louisiana1 -
Oh my, Jilong that is so clever. I have seen beach baskets like that but their sides are much higher. My big old cat The Tuna is about 26 pounds, so I know that would not work. So for now we have such sweet neighbors who are willing to take care of the old man!
Pam and Ron, 2018 T@B 400 named Felix, white with black trim, pulled by a 6 cylinder Toyota Truck.0 -
@PamHoward, your old man Tuna and my old man Bossman have a lot in common. Boss tipped the scales at 18 lbs and he's on a DIET. I dunno where he's hiding da twinkies, but I have yet to find them!! (psssst, Harvey may be in on it).
2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)1 -
@Ratkity, Harvey is more than likely the culprit for the Twinkie episode. Have you checked yer charge account lately????
Just try to keep poor Popper away from those scoundrels!
Eric aka: Lone Wolf1 -
I order so much on Amazon, it would be easy to fool mommy and sneak in an order or 100.
2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)0 -
Eric aka: Lone Wolf0 -
I thought of using the under bed storage for the litter box with an access port cut through the front of the bed frame. I don't have my Tab yet so I don't know if there is structure in the way. I like this idea better and it was my intent to use the bathroom initially but thought it would be in the way.0
That's where the factory mounts the inverter if you order one. Even without an intverter its a pretty cramped area and probably not enough height to allow a cat to get in the box and do its business.davel4wa said:I thought of using the under bed storage for the litter box with an access port cut through the front of the bed frame. I don't have my Tab yet so I don't know if there is structure in the way. I like this idea better and it was my intent to use the bathroom initially but thought it would be in the way.2023 F-150 Powerboost hybrid
2019 T@B 400 Boondock0 -
I keep the front table in the couch position and the cat box underneath-though it is a small-ish box
- 957 Air Conditioning & Refrigeration
- 922 Introductions
- 75 Teardrop Groups & Links
- 918 Tips & Tricks
