New Tab owner. We have a 2018 TAB s. We were hooked up to city water for 2 days, on third day water came flowing out of overflow tube. Unhooked the hose and now when we put the water pump on, water comes out of the overflow hose again. Also, no water coming out of hot water faucet.
1 ·
Now... water sources and inlets
There are two inlets for water.
1. One is for city water. You'll need a pressure regulator to drop the water pressure to <50 psi. A seasonal water filter is optional, but I know you'll wish for one when you camp in some state or national parks with a sulfur odor in the water (harmless) or even tiny bits of sand it the water (just crunchy). When the pressure is too high, the over-pressure valve in the Alde engages and it looks like your T@B is peeing from the center of the bottom of the trailer. You don't have to run the pump when you are on city water.
2. There's a tank water inlet for water. It looks like a flap (unless they changed the inlet - someone will let me know with a picture). When the water overflows from the correct overflow tube, the tank is full. Then you use the pump. It's best to fill the water tank inlet at home, run the faucets to fill the Alde and get all the air out of your lines and the Alde. Then top off the water tank. Remember, the pump stops running by itself when it reaches pressure. To be miserly with power even prevent the pump from running dry by accident, lots of people turn off the pump when not using any water source.
If it's draining from the location shown in this photo, the yellow valve is open..
If it's from the largest black tube farther to the left in this picture close to the drivers side of the trailer, then it may be from the Alde pressure relief valve that drains from a clear tube attached to the Alde pressure relief valve, which might be bad or stuck open.
Again, thanks to everyone for answering and helping us.
Evanston Wyoming home
Finally! New Owner of a 2017 Tab 320S!
Woohoo!
