Many thanks, at least I can feel relieved that my confusion is not of my own making! So I guess I should take the cautionary approach and bypass the boiler. Of course I'll need to be doubly sure the boiler is fully blown out...ChanW said:Yep, the various info on this has been contradictory at times.
Way back in 2014 or so, Alde came out with a recommendation that the fresh water heater jacket should not be exposed to antifreeze. They said it had something to do with the rubber seals not reacting well to the heated RV antifreeze. (I think previous to that they'd said it was no problem having antifreeze in contact with the hot water system. My guess is that it was a cautionary 'just-in-case' recommendation, maybe because they had little experience with US brands of RV antifreeze.)
The announcement was kind of a drag for us, because we'd already winterized with antifreeze in the hot water system (there was not a bypass system on the early Alde Tab system), and we'd gone ahead and use the Alde with it winterized, doing some winter camping. (We've since stopped using the antifreeze method for winterizing the pipes!)
At any rate, the latest word is to not allow hot antifreeze in contact with your fresh water heater jacket. Thus the bypass valve system was incorporated into the Alde system design.
Thanks, again. I am now beginning to wonder whether I should run antifreeze through the system at all (just use it in the drains and traps). My first concern was having enough of an air pump to blow out any residual water in the pipes (I will be using a volume air pump rather than a high pressure pump). However, the schoolboy scientist in me reckons that even if there is a dribble of water left in the system, none of the pipes will be filled and under pressure therefore any water expansion caused by freezing should not be a problem. If the pipes were copper rather than pex, of course, maybe I'd be more concerned...ScottG said:I'll emphasize ChanW's comment that the concern seemed to center around heating the antifreeze--i.e., using the Alde for cabin heat after the supply plumbing had been winterized.If like most of us you are just winterizing and not planning to used the camper again until you've de-winterized in the spring, there is probably even less concern.That said, I don't know of a compelling reason to fill the Alde with antifreeze. It'll cost you an extra three gallons and create that much more flushing work in the spring. If you've emptied the tank and blown the lines, even a little residual water won't expand enough to crack anything.
I did drain the boiler yesterday, but really did not pay attention as to how much water escaped. Plus, I've yet to blow air through the system. However, once again I'm confused by both the Nucamp and Alde manuals! I drained the boiler by releasing the pressure relief valve and opening the hot water drain valve but I'm unable to identify the boiler drain valve to which they refer! Does that exist and where should it be on my Alde 3010? Thanks!cgstarry said:I’m glad to see you asking this jTeztab. I was wondering the same thing. How much water did you get when you drained your boiler? I got two gallons but expected about a half gallon more from my 3010 based on a lot of what I see documented here...
teztab said:...However, once again I'm confused by both the Nucamp and Alde manuals! I drained the boiler by releasing the pressure relief valve and opening the hot water drain valve but I'm unable to identify the boiler drain valve to which they refer! Does that exist and where should it be on my Alde 3010? Thanks!
ChanW said:I'm not sure I can see what year you have, but our 2014 doesn't have that extra Alde drain valve. All we have is the drain valve on the hot water line and the drain valve on the cold water line. Plus the FW tank drain.
Yep, I've got one of those, too, in addition to the yellow flapper valve. I also take it to be some sort of pressure relief valve, but I'm not sure why they system needs two, or why the yellow valve was apparently added as an afterthought.ChanW said:
