Once you have a steady stream of water coming out of the hot tap with no air sputtering, we assume the Alde hot water tank is full (except for the allowable air cushion). I asked the same question😁
And even if you turn it on without water in it, there shouldn't be a problem. Many owners still use it for cabin heat after the plumbing has been drained for winterization.
2015 T@B Max S (320) 2015 Nissan Frontier SV V6 4x4
