While we were out this week I encountered an error code while hooking up our T@B. I always check the pedestal before I hook up, with the plug in 3 light circuit tester. All tested good so I made our connection. When I went inside I noticed the trouble code e02 and consulted the card with the codes. It indicated a missing ground connection, and it had shut down the shore power. I rechecked the pedestal and also the outlet by the counter sink. Still showed good on the tester and the gfi had not tripped. I over rode the EMS got power back and Called Progressive. It was later Sunday afternoon and no one was at work so I left a message. We had very spotty Cell coverage so was not able to get a call back. We had camped at this exact spot earlier in the year but did not have the Progressive system. When we got home we had a message from Progressive and I returned their call. I explained to the service tech the issue and he said the pedestal had a bad ground. I mentioned that I also try to have the Alde system off when powering up and Down. He suggested that I should open the control center and remove the time delay jumper. This will give a 130 second buffer on power.
Moral as I see it, The Progressive caught something I did not know and did it's Job. Really like the system, And, Not sure how much I trust the plug in circuit tester.
I read the RVTravel.com newsletter and the RV electrical guru Mike Sokol now writes a column. He advocates first checking the pedestal with a NCVT (non-contact voltage tester) to identify loss of ground to avoid a potential Hot Skin event. There is actually a group of RVTravel.com members who have volunteered to check campground pedestals and report their findings to campground managers and to Mike Sokol to help define the limits of these kinds of problems.
http://rvtravel.com/how-to-check-pedestal-power-when-hooking-up/
Having a built in surge protection system eliminates not only the manual work, but also provides insurance for the trailer and the peace of mind in knowing that your sensitive and expensive electrical components within it (e.g., the Alde, TV, Jensen, lights, etc.) are being protected and monitored at all times. Well worth the initial investment cost!
The camp host said most campers do not use anything and plug right in and he knew of this problem post. Luckily the 20amp plug was fine.
Sold 2023 Tab 400
Sold 2018 T@B 320S
If I understand this correctly, the procedure is to turn the pedestal breaker OFF, plug the EMS PT-30X into the outlet, connect your umbilical cord to the EMS PT-30X, connect the umbilical cord to the trailer, and then reset the breaker on the pedestal? After the EMS PT-30X completes its checks, if everything is OK, power then flows to the trailer. If the pedestal does NOT check OK theEMS PT-30X will not allow power to the trailer?
After the EMS checks out ok, plug the TaB power cord into the EMS.
Sold 2023 Tab 400
Sold 2018 T@B 320S
