Hello,
We are brand new to trailers and to 2018 320 CS -S. I have a question about tanks when the trailer is parked for a few weeks. First of all, we live near San Francisco and the weather rarely freezes so I'm hoping we don't really have to winterize. We took out he trailer for a one night trip and used city water and electrical hookup. We emptied gray and black water but did not do a full flush of systems - no solid waste in the black tank and only one night at that (and our ignorance about such things). My question is, do we have to empty all tanks including low level water (from hot water tanks etc.) if we won't have time to use the trailer again until December?
When is the complete flushing and emptying of all tanks required? How long can you leave your trailer parked without worrying about these things?
0 ·
If you have a clamshell you have a 2-way fridge. No propane. It works fine but if you plan to camp where there are no hookups you'll have to think about battery management.
I also live in the SF Bay area and store my trailer in Petaluma. I don't fully winterize but I do drain the tanks if it looks like there's going to be a pretty hard freeze overnight. I don't know that it's necessary but it makes me feel better.
Join the NorCal Rally group:
https://www.facebook.com/groups/NorCalRally/
Regarding the black and gray tank. I know some folks just put an enzyme product (Happy Camper) and leave it sit unemptied - if they plan to use it after a short break. Same thing with extended boondocking with no dump available. You need to make sure that there is water in the commode to help maintain the seal and prevent sewer gas from escaping into the TaB. Also, you must maintain water in the sink/shower traps to prevent odor escaping. If you dump the tanks, it is not hard to flush them at the dump, then add some enzyme product or some Calgon and Dawn (GEO method) with a gallon or 2 of water.
You should empty the fresh water tank. Again, don’t encourage any badness in the tank.
For those of us who winterize and put the TaB away for winter, we of course flush, empty, blow and add antifreeze as indicated, then flush and sanitize the fresh water tank and plumbing in the spring. In your case, I would say anytime you know you won’t be using the TaB for an extended time, follow the above info. And sanitize at least once a year - just do it regularly maybe before you take it out the first time after a long period of absence.
Hey members who don’t winterize manage your tanks - how do you do it?
When you use the gray and black tanks, they say you should fill them to at least 3/4 full then dump to avoid things sticking to the sides of the tanks.
If you used city water and turned on the hot water faucet until no further air comes out, then your Alde hot water tank was filled. It is easy to drain any residual out of the fresh water tank - valve is in front of the passenger side tire. Yes, you only use the pump and your fresh tank when not connected to city water. The fresh tank is filled manually via the port on the front driver side.
Read the manual and the Forum!
Good luck!
Having a microbiology & med tech background, I figure no water means no invitation for microbes.
