so I’ve been learning about towing my T@B outback, and it’s been going well with my turbo Forester. The friction sway bar makes a huge difference to stability. It drives like a train in even the windiest conditions.
but....interestingly, I finally checked the tongue weight and found it was 110 pounds. I know that the recommendation is that the tongue weight should be 10% of the trailer’s total weight which would be about 200 pounds. So....I’m pretty far off that recommendation.
I assume that if I towed with freshwater in the tanks that I would get closer. Winter is coming, so I won’t be doing that, and generally I am trying to keep my trailer towing weight as low as possible.
I dont know know if I want to go all the way to 200 pounds, but I think it’d be a good idea to get a bit more weight on the tongue.
I could take the the tire off the rack on the back and put it on the tongue, but I assume that would add too much (subtract from the rear and add to the front would add a lot to the front).
I think my current plan is to take my 3-gallon water jugs and put one or two of them on the front rack. I could easily move the water off if I needed.
does anyone have any suggestions?
T@B 360 Black Canyon, 2021 Jeep Grand Cherokee V6, Maryland
(previous 2018, T@B 320 Outback)
0 ·
Huntington LI
I added a second AGM battery in the battery box on the tongue so that should more than balance that out (obviously).
i weighed it with a bathroom scale directly under the coupler. I made sure that it was at the exact same height as the car’s ball when it was being towed (which is pretty much exactly level).
Has as anyone else weighed theirs? Their outback?
Huntington LI
Huntington LI
Filling the FW tank and putting a Honda generator on the front rack bumps that up to 165lbs.
Moving spare to tongue, and taking generator back off the rack raised it up to 177lbs.
Taking off the spare completely, but putting the generator back on... 186lbs (generator weighs more than the spare).
And finally with spare and generator up front: 222 lbs (still with FW full). If I didn't have the heavy battery bank in back that would be more like 300+ lbs (too heavy).
TV 2005 jeep TJ unlimited
Alaskan Malamuthe on board!
While not a full feature Boondock/Outback my T@B has the pitched axle and front rack (Outback platform). Have one Tongue Weight data point with T@B Coupler at towing height:
Tongue Weight 204 pounds
Coupler Height (TOP) 18-inches
Tanks 2gal W 16%; 7gal B 85%; 14gal G 75%.
Spare mounted at Jack Post
Battery Grp-24
Propane Full tank
Platform boxes None
I felt the back of my car bounced a bit more then i liked when it was empty towing of the dealer lot. once I added a 25 to 30 pounds to the tongue with a storage box the bounce was reduced and ride was much better.
Without me measuring it. I suspect the numbers from nucamp might be a bit off. The number from nucamp shows to be a very balanced trailer right off the dealer lot. My experience shows otherwise. It needs a bit more weight at the tongue. Some post from other members stated that their ride improved when moving the spare to the tongue. this mean it needs more weight at the tongue.
I put two 3-gallon water jugs on the storage platform. I figure that probably added 20 or 30 pounds to the tongue weight--getting it to around 150 pounds (I didn't re weigh). It didn't bounce as much as before.
Now, first thing, I'm going to weigh the trailer. There a weight scale in Oshkosh, about 30 miles south of here. That will give me my base i think.. Then I'll bring it back to base and do some weights with bikes and without and with and without the wheel. That will give me some numbers. If one has to go, it will be the wheel I think. I bet right now I'm at about 350 or so, which is too heavy. I was told my Ram truck doesn't really figure into this.... So... then my wife said I should look into a weight distribution hitch. Not sure if that is an idea...
205 pounds seems on the light side for your setup, but perhaps you've counter balanced well..
When weighing my trailer, what would you have attached in doing this? Bikes, extra wheel? Also, have to see the procedure in the process. One guy said that the weigh station will tell me what to do...
Going to the NuCamp rally?
2016 NuCamp 320 T@B Max S
T@bbey Road
Appleton, WI
Huntington LI
@TerryV6, no, we've still got our 85lb Trojan 1275/150AH GC battery in the tub & spare tire on the jack. I double checked the height of my wood post on the scale & it was exactly the same as the leveled tongue. Propane tank is full, but we don't have any bike rack or extra box, just plastic tub. Though we do have a bunch of solar cables, security cables, hoses, metal shelf units, wood blocks, etc stored behind & under rear seat. I think you should weigh the trailer loaded with how you plan to travel.
@rcuomo, your weight sounds comparable to ours, after accounting for your platform, bike rack & bikes.
Like you, @TerryV6, I've been wanting to get our trailer weighed, so went today to the nearest town with scales & got it done for $9..
First put the front tires on the scale, then front & rear, then pulled off leaving just trailer tires on scale for trailer axle weight. That's what the guy suggested to get weights for all 3 axles.
At first glance it appears our tongue weight I got at home was almost exactly 10%, but now I'm thinking it's more like 9.2% if you add the tongue weight back into the trailer weight. Some procedures I've read say it should be 9-14% rather than 10-15%, so maybe we're close enough? I did load bicycles & popup tent (& wife) into the van, but still need to add cooler, clothes, chairs, etc.
Maybe if I added another storage box to the tongue & moved some hoses &/or cables there, we may be better off.
Here is Another CAT Scale Report.
Gross axle weights are useful to know, but one more step would have provided actual tongue weight.
See: https://www.etrailer.com/faq-how-to-determine-trailer-tongue-weight.aspx
It adds a couple minutes to the procedure but it's worth it if there isn't a line behind you at the scale. ;-)
2005 Toyota Sienna Weight Ratings (lbs)
[vs. Our Actual Weights]:
GCVWR= 8700 [6940]
(Gross Combined Vehicle Weight Rating
= Total TV + RV + contents)
GVWR= 5690. [4900]
(vehicle, people, cargo, hitch & tongue load)
GAWR= 2845 [F: 2500, R: 2400]
(front or rear axle)
Trailer + cargo= 3500 [2040 +206 tongue]
Weight-Carrying Hitch= 350 [206]
Tongue Load= 9 to 11% [206/2246= 9.2%]
(for weight-carrying hitch)
Brakes= required for trailers > 1000 👍
It's possible we may add up to 75 more pounds, mostly to TV, but it looks like we are within specs in all areas. But, it is good to know that we are near the low end of the tongue load percentage range, so can afford to add or move more to the tongue. I would like to find a way to add a box or boxes to the tongue, but there is only about 6 inches of space left between the tub & spare.
It seems to me that getting a 200 lb weight from a 0-400 lb range scale would be more accurate than looking for a 200 lb difference in a vehicle weighing 5000 lbs using a scale that ranges up to tens or hundreds of thousands of pounds.
