The fan is a cooling fan for the electronics in the breaker box (a.k.a. the converter). It comes on automatically when needed and has nothing to do with whether you have the heat on or off.
I've noticed that mine tends to run when I first plug the camper in to shore power, or when it's charging the battery. It shouldn't be running constantly however. Is that what yours is doing?
2015 T@B Max S (320) 2015 Nissan Frontier SV V6 4x4
@aprille4, your Alde system heats via the fins under your bench and behind the rear wall. There is no fan involved. Ditto what Scott said regarding the converter fan.
