MuttonChops
Member Posts: 1,883
I'd like to have a reference drawing of the framing to help with future modification projects. An while I have not actually asked nüCamp for a complete frame location drawing some forum members have commented they have not been able to obtain that level of construction detail. So we need to collectivity build the knowledge during our various projects/tours/nüCamp conversations.
We are beginning to
acquire bits & pieces of the outer wall frame placement in the
Azdel Composite Wall.
= - During the recent Doorway
Exit Grab Handle discussion we learned from nüCamp how the door
latch side
cut-out edge and forward side window cut-out edge do have
1x1 inch Aluminum Framing.
= - Several factory floor tour pictures taken
by forum members clearly show Aluminum at most
of the wall outer
edges. In some pictures it is not 100% clear there is Aluminum.
= - Finally, one mods posting about adding a rear area wire shelf notes
that Aluminum Frame was
found when screwing in a mounting bracket.
RED = = = nüCamp
conversation
Off-RED = = = Tour
Pictures (ceiling line)
BLUE = = = guess
GREEN = = = reported in a mod posting (dimensions and trailer side not clear)
I believe the rear wire shelf bracket item on your list was mine here..
http://tab-rv.vanillacommunity.com/discussion/comment/92423
The screw which went into metal framing was the one on the 3rd photo at the rear corner. I'd have to measure to be precise, but I seem to recall that I drilled about an inch or so from the ceiling. At the time it was a surprise, because I was only expecting support from the thin wall.
I believe this should not imply any vertical wall stud, but rather it is just the perimeter wall framing. This framing is clearly shown in @CincyKid 's photo #12 here..
https://tab-rv.vanillacommunity.com/discussion/7276/t-b-320-factory-photos-showing-locations-of-items-before-hidden-in-walls/p1
Although this does not show the vertical width of the framing, as to how far it extends inside the wall, but I'd bet it's at least 1.5" for strength in supporting the roof.
His second photo shows how the ceiling framing (spaced 8" OC) is tied into the perimeter wall framing.
I'll see if I can get a more precise measurement of my screw locations, but both side walls have the same brackets going into metal.
BTW, my second photo of the bracket going into wood on the driver side also shows a pocket hole screw which mounts the rear vertical shelf support into the wall, but whether that goes into metal or not is another question. It might be possible to explore that further by removing the screw & probing the hole. If it goes inside a metal tube, a curved paperclip wire should rotate freely, while it would not inside foam.
Also' I'd be surprised if the red vertical stud shown in your drawing next to the window really exists as shown, though it might be more likely on the other side.
Maybe something like this..
Seems less than ideal that they would use a "floating" frame around the window without tying in to other framing, but who knows?
The necessity of the vertical green one at rear seems questionable to me.
CincyKid
Cincinnati, OH
Those are the only holes I made near the wall-ceiling corner; though I have some cargo net mounting brackets that are screwed into different ceiling studs that are spaced every 8" from seams in the ceiling.
My stud-finder found bupkis. I tested it with a fresh battery on my house wall & it found both sides of wood studs under drywall, but it could not find ceiling studs at all in our T@B, even where I knew they were there. It is supposed to work on metal studs too, but I suspect they must be steel or some kind of ferrous metal and not aluminum.
I say this because I just reviewed "The Air Force Guy"'s 320 factory tour video, and it shows a roof panel (@ 3:30) that appears to cover only the back of the roof up to a point just forward of the ceiling fan. So it looks as if the roof goes on in two pieces. If that's the case, wouldn't it depend on the wall for support? While I understand the principle of an arch, it seems like the wall could be providing some needed support to the roof by both it's own complete arch plus maybe a vertical stud at the rear of the door (and presumably another in the opposite wall).
And then there is the argument that each component depends partly on the other to provide the support each needs. The two vertically stacked 1-inch arches in both wall & ceiling together provide a 2-inch tall double arch.
Zircon StudSensor e50 Electronic Wall Scanner https://www.amazon.com/dp/B01HTFHOEI
Comparing the bright white of a known foam cut-out to the darker grayish edges suggests the doorway and wheel well are edged with Aluminum square tube. Of course there are also a couple images that could be showing whiter foam in the doorway arch - - too few images and poor quality to be certain one way or other.
Have also noticed the Roof Rail offset/overlap of the outer fiberglass+Azdel is around the entire wall panel (a change from v1 & v2). In addition to the roof ladder arrangement there is a ladder frame on the bottom aft of the floor end and would suspect another ladder under the diamond plate - - have not seen a picture.
I believe this thread grew out @Bill@ndRox's grab handle topic where he offered to take the lead in contacting NüCamp, then @jgram2 provided them a link to the thread, but I've never seen NuCamp contribute info to the discussion (understandable, as I'm sure they have more important things to do). I've not had great success contacting NüCamp by phone, but thanks for the reminder, @ScottG, as I am still waiting for parts info from August while using duct tape to hold things together.
I've attempted to capture everything we have learned from factory tour pictures, our experience, conversations with nüCamp, and the nüCamp Passenger Side Sidewall drawing posted on another thread in a single PDF file.
Have also input the information into a simple drafting CAD program so corrections and additions of new information can be completed.
File attached for your review, comment, usage. Dec-18-18 Update
Just one minor comment..
The 3D images on pages 1 & 6 are both rendered with a perspective as viewed from above; so my brain was suitably conditioned to render the next 3D image on page 7 from the same perspective (viewed from above & behind it), which puts the door on the wrong side. It took me a while to be able to see it properly, as if viewed from below like you were laying on the ground on drivers side & in front of it & looking up at it, then the door appears on the correct side.
I think keeping the same viewing perspective for all 3D images in the document, if possible, might help avoid creating a brain teaser.
The 3D view on page 8 is even harder for me to reorient my viewing perspective. I know what part I'm supposed to be looking at, but at first cannot picture from what angle I am supposed to be viewing it & it seems confusing. I think maybe it's drawn as if the viewer is laying on the ground close to & parallel to the drivers side with head towards the rear and behind the rear end looking up under the rear at an angle?
Still, very helpful to have these 3D images to be able to see through the structure how it all fits together. And I see you used colors to show the two separate ceiling framing "ladder" pieces that support the roof.
Nicely done!
UPDATE:
Some of my comments above may have been rendered moot since I first made them, by virtue of @MuttonChops having updated his pdf document with a new version.
My brain still struggles with page 7, but at least we can now see the intended interpretation. Thanks, that helps!
Here is a January 7, 2019 video on the construction of the T@B 400 which I have not previously seen as well. I apologize if these videos have already been posted. (Greg)
