While compiling the specs on our new 2019 T@B400 Boondock Lite, I looked for a PDF tire brochure to know the limitations, warranty, etc. After a 2-day education cycle during which the factory tech support did a great job of accurate and valuable response, I was able to gather together what I'd need to know should I have a sidewall problem in the field and need a new tire.
The tires are Rainier Apex ST APC-X ST235/75R15 110/106M mounted to an aluminum rim and 5-bolt pattern.
They come with a 6-year warranty and a speed rating of 81-mph
Using the TREDIT ADVANTAGE app from Google or Apple, you can receive nationwide roadside assistance under this warranty.
http://www.tredittire.com/tredit-advantage-programThe spare is an ST205/75R15 mounted on a steel rim.
This post is just for general reference by the community as the tire is not readily available other than in through www.tredit.com at their Elkhart or Oregon locations at the present time. As this model doesn't appear on their website and local branches may not be aware of it in the off road configuration, you may need to give them part number #RNAP235X15CTL.
From what I've seen and heard, the above information shouldn't be needed but if you do, this will simplify the replacement process. New boondock owners can register the tire on the Tredittire website.
The Boondock wheel is also stamped "L55205R" and "15X6.0J" on another spoke. I have not been able to figure out what those refer to. The wheel is a 15" with 5 lugs (4.5) wheel, so I would not think the "15X6" references a 6 lug wheel. Any ideas on what the stamps refer to?
Also, @Awca12a , did you question nuCamp as to why they say to contact Lionshead Tire and Wheels (http://www.lionsheadtireandwheel.com/) re the tires and wheels warranty? I searched the Lionshead website and they do not appear to carry either the Rainier ST tire or the Thoroughbred wheel.
I agree that it is going to be difficult to replace the current Boondock tire or wheel with a short turn-around time frame, since a tire shop would likely have to special order both. The aggressive look of the Rainier ST APEX is part of the appeal of the Boondock package, so it is a shame that it may not be available (or at least easily available) in the future.
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePo4; Solar: Renogy 100Ah Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
Huntington LI
My dealer did say several "off road" trailers use the ST235/75R15 size with aggressive tread. I have a real concern about any mud/gravel balling up on this tire will likely be rubbing the minimum clearance fender and start breaking the plastic. The Boondock lite package adds 2 1/4" additional ground clearance (I finally found that published in the NuCamp brochure) and other than the aluminum tub (which is actually a better design and more durable) I see the Boondock Lite package mostly as an appearance package with a slight bit more ground clearance, BUT in no way does it add a ton of off road capability.
Quoting my dealer; "Most of my manufacturers use Westlake (sometimes sold as Goodride) in a more aggressive mud tread, but there have also been more all-terrain treads, too. I think it all has to do with what is available at the time they are ordered."
I will see how these Boondock tires work out, BUT may ditch them for Goodyear Endurance ST205/75R15 so as to have same size as spare. or possibly ST225/75R15 on all three rims.
I plan on adding a TST TPMS as soon as I can too, knowing tire pressure and temperature is very important if you want to help your chances of NOT having a tire failure with subsequent damage to the trailer.
i was wondering if an LT tire with the same dimensions would be a suitable replacement for the odd sized ST stock tires? It seems that the LT tires are much easier to find in this size.
Would an LT tire with a C load range be a good choice for a 400? Or is it a bad idea to replace ST with LT in general?
2016 F150 SuperCab 4x4
NorCal - Napa Wine Country
Huntington LI
While shopping for my T@B 320S all the Boondock/Outback models on the dealer lot had Westlake ST 235/75R15 tires. When my factory order unit arrived three months later it had Milestar 235/75R15 XL tires.
'XL' are extra load and have stiffer sidewalls at the sidewall-tread interface. They are not 'ST' or 'LT'.
Milestar load rating is 2271#, speed rating 118 MPH
Took the opportunity to replace the cheap valve stems with the high-pressure type that is rubber near the tire and metal on the stem. If you have one of these tires, check your air in the driveway before heading out.
SF Bay Area
My replacement cost $4.50 at the local commercial tire shop and was a VTR TR-600HP 1-1/4" High Pressure Brass Rubber stem.
That page also states, "Also consider that Special Trailer (ST), as well as Light Truck (LT) tires are fully rated for trailer applications. This means ST- and LT-sized tires can carry the full weight rating branded on the sidewalls when used on a trailer." That was a key point for me.
In reading this and some of the Airstream Forums I feel like just driving the stock BL tires for this season and switching to Michelin Defender LTX M/S 235/75R15 XL when life quiets down a bit. This is in lieu of searching down the road for that one obscure pair of ST- tires that will work on the BL and look aggressive and cool.
In your spare time:
Older posts, but very useful for the technical details and 1st hand experience::
http://http//www.airforums.com/forums/f438/235-75r15xl-vs-225-75-15-trailer-tire-83262.html
http://www.airforums.com/forums/f438/anyone-look-into-the-235-75-r15-michelins-166118.html
...and, when all was said and done:
http://maze.airstreamlife.com/2015/08/26/why-you-might-be-wrong-about-everything/
2019 T@B 400 BL
2021 Toyota Sequoia 4WD
Edited for language - Sharon
While I'm aware of the ability to use an LT tire, I'd like to stick with ST tires even if it is a boneheaded move.
Nobody makes an ST235/75/R15 tire and the only dealer who handles it for nuCAMP doesn't show it on their website or brochure. They did, however, confirm by phone that the tires are load rated C/6 with a 2340# carrying capacity and fits on 15" x 6" wheels.
The C/6 load rating according to the tire experts/salespeople seems to be the problem. When you put a higher load rated tire on the trailer but don't load the tire to within it's rating while still inflating it as specified, you end-up wearing down the center of the tire because it's the equivalent of over-inflating. At the same time, inflating less than specified impacts more than just a reduction in load rating; apparently, it effects the sidewall stability which is the purpose of an ST tire. So, I was advised to stick with the C load rating and possibly the D but certainly not the E. Note: C/6 means 6-ply, D/7 means 8-ply and E/10 means 10-ply.
There are no ST235 tires commonly available or even after making a concerted internet search so we have to use ST225 which is 1/3" smaller but will fit the 15" x 6" wheels.
Tire Track said the only tire they could offer is the Power King TowMax STRII with a D load rating of 2540# capacity when run at 65psi. Etrailer offers the Taskmaster Contender Radial C22515D with a D/8 rating of 2540# at 65psi.
When I brought-up the Goodyear Endurance ST225/75R15 to both, i was told its E/10 load rating of 2830# capability at 80psi is simply too high. Etrailer affirmed that the Taskmaster has the quality to do the job and in that respect compares comparably with the Goodyear. While they offer a C rated one from Karrier, I didn't get a warm feeling about it's quality. While searching reviews, I ran accross a Q&A covering this: https://www.etrailer.com/question-251209.html
If you had to replace your Boondock ST235/75/R15's, what would you do?
Actual trailer weight and equipment details given to the salespeople were:
In a name brand tire, that is only two options I found. One of the reasons I wanted to buy ST205/75R15 tires on a Boondock was what we are discussing here (standard trailer tire size), but was told no "partial" Boondock package, all or none. It is an easy enough swap I suppose, but a waste of money after the fact.
Anyone know if lug patterns, rim width, offset, etc. are the same between standard 400 rims and the Boondock version? I guess worse case, order a set of standard wheels, take them to the tire store and get some proper trailer tires mounted.
2019 T@B 400 BL
The procedures to jack it have been cleared by the factory and I hope are cogently documented in the Unofficial Manual.
Tongue weight is figured out. If you have a Boondock it’s higher tongue weight than if you don’t. Nobody know why. So Buyer beware and plan accordingly. In retrospect, no value in the Boondock package given the tire and weight problems but now nobody can claim ignorance.
Tires remain a problem but can be solved for under $300. If there was an answer to the field replacement of a damaged tire, factory probably would have chimed in. I expect they will eventually post specs for a standard ST225 and show new weight capacity and clearance specs if you do.
Trailer is great and I would buy it again only without Boondock. Just wish I didn’t have to buy the TV twice.
