Replacing Speakers
I'm thinking about replacing the speakers in my T@B. What have others replaced theirs with?
Also, the speaker wire in the unit seems awfully wimpy. Has anyone gone to the trouble of replacing the speaker wire with something more substantial. When it comes to speaker wire, we've always used the really good Monster Wire in our home system. Does it really make that much of a difference?
Carol
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
  • Nomad
    Nomad Member Posts: 7,209
    From what I've read, in blind tests it doesn't.
    In one they even fooled em using coat hangers as wire.
  • jkjenn
    jkjenn Member Posts: 6,423
    It is worth it for cords you unplug and plug in a lot, but for speaker wire, I would just get one with solid reviews. Crutchfield does some good reviews. You might also check Amazon Basics. I have been  happy with their a/v supplies.
  • Nomad
    Lamp chord, nickle a foot :-)
  • Spruce1
    Spruce1 Member Posts: 100
    For replacement speakers I recommend contacting Parts Express.  Very competitive prices and very knowledgeable staff.  To give you a recommendation they'll most likely need some basic info like speaker diameter you're looking for, the volume (cubic inches) of the cabinet in which the speaker is housed, the brand of receiver/amp, power, etc. I wouldn't worry about using the factory speaker wire.
    2014 T@B-S
    2019 Honda Ridgeline, AWD, V6, 5,000 lbs towing capacity
    Minnesota
  • lara9209
    lara9209 Member Posts: 45
    I noticed that there are 3 speakers on the Jenson ... but only two in the trailer ... is there wiring to a 3rd speaker that's not installed?
    John & Lisa, 2016 M@x S, Silver/Yellow, Hood Canal, WA, TV = 2008 Toyota FJ Cruiser
  • Photomom
    Photomom Member Posts: 2,217
    Don't tell my husband, he'll want to add a subwoofer.
  • Verna
    Verna Member Posts: 6,876
    I figured it was for the CS (Clamshell) for the galley speakers. Sure the third speakers aren't used in the other models, but from a business sense it would make sense for Pleasant Valley to only order one Jenson model. It would also make sure with one model, that the correct model is always installed.
  • IrishCamper74
    IrishCamper74 Member Posts: 237
    I'm a fan of Alpine & JBL. I have both in my car & am very happy with them. As for speaker wire, you don't need the most expensive kind. It all does the same thing but personally, I'd stay away from the very cheapest.
    Talk with a local car audio shop. They will have more specific information on your options & installation costs. Think of it this way, Best Buy may be convenient but 50 feet away, they are also selling washer/dryers. I'm a fan of giving local businesses my $$.
    I wish there were more options available in t@gs aside from Jensen. Even Sony would be somewhat better. Maybe in the future, it could be an option.
    Personally, I like good sound, I work in the business, sort of.  B)
    Hope you find what you're looking for.  :)
    Light a campfire and everyone's a storyteller. ~John Geddes
    2017 t@b CS, silver with green trim.
    TV: 2017 Honda Ridgeline.
  • Nomad
    Photomom - Gotta have a subwoofer or it's nothin but a tinny rendition. Gotta have the Boooom Da Boooom Da Boooom.
  • Mr_Mrs_Gnome
    Mr_Mrs_Gnome Member Posts: 241
    "It's all about that bass"
  • Nomad
    Yep - Of course I'm biased. Was a muscian (bass player) in a former life.
    But, the science shows that those big, deep bass waveforms carry all the others on top of them.
  • jkjenn
    Yes... and carries all through the campground.
  • Nomad
    It's only good if you can feel it in your bones :-)
  • mash2
    mash2 Member Posts: 584
    I added a couple of old Minimus 7 speakers in the countertop corners to improve the sound in the T@B.  Also replaced the original radio (I have a DM) with a pioneer unit for better sound. Don't use often, but like the better sound when I do use them.
  • Nomad
    I didn't get mine with the media package. Figured builtin stuff would be out of date before it even shipped - Kind of like car nav systems. Have all my music on the iPad and stream it to bluetooth speakers.
  • Mouseketab
    Mouseketab Member Posts: 1,260
    Maybe some more insight. I have a Dutchmen T@B that had a TV/DVD combo unit originally and the speakers were wired to the original TV. I have since replaced that TV with a digital model and did not wire that TV to the speakers. Instead, I installed a Pioneer CD/FM/AM unit and added a XM transmitter. I wired that unit to the existing speakers. I have two speakers under the back cabinets inside and two speakers in the galley. I have noticed some distortion lately.
    It sounds like just replacing the speakers with a higher end speaker of the same size will help? Going to the trouble of rewiring the existing speaker wire makes little/no difference?
    Carol
    MOUSE-KE-T@B
    Harvest, AL
  • Kiddydoc
    Kiddydoc Member Posts: 15
    From my April 2015 post under "T@B speakers"   Just finished replacing the stock speakers with Kicker DSC5's.  They were under $50 a pair on Amazon.  They fit perfectly in the existing holes.  Simple matter of splicing the new connecting wires with terminal to the old wires.  I had to redrill holes for the mounting screws so that the Kicker emblem was oriented correctly (optional).  The sound improvement is well worth the investment, they even pump out a little bass.  The sound is cleaner and much fuller.  Still happy with them a year later!
  • db_cooper
    db_cooper Member Posts: 749
    Were they the 5.25 inch kiddydoc?
  • larrygon
    larrygon Member Posts: 255
    Replaced my speakers with a soundbar. PXlated is correct, cheap wire does just fine. Find what sounds good to you and you will be happy.
    "Great spirits have always encountered violent opposition from mediocre minds." Albert Einstein
    2015 T@B M@X S White with Grey trim | TV 2021 Ascent Touring | Flagstaff AZ.
  • Kiddydoc
    The Kicker DSC5's are 5.25 inches and fit perfectly in the existing holes.
  • jcfaber1
    jcfaber1 Member Posts: 318
    +1 for Parts Express.  For more upscale you can try Madison.com.
    John
    2007 T@B
    Rockford, IL
  • jcfaber1
    edited May 2016
    Darn spell checker.  Madisound
    2007 T@B
    Rockford, IL
  • wizard1880
    wizard1880 Member Posts: 442
    Even the clamshells have just 2 sets of speakers--inside and outside.  The 3rd set are for larger RVs which these stereos are also sold with.
    T@@bulous
    2014 T@B CS Maxx
    Martha Lake, WA
  • webcrawler
    webcrawler Member Posts: 133
    I am usually pretty picky about sound quality and I like the speakers my 2016 T@B...
    Kennesaw, Georgia
    2016 Silver/Black T@B M@x S with Scuba Black interior.  2015 Lincoln MKC AWD 2.0L Ecoboost tow vehicle. Tekonsha Prodigy wireless Brake Controller.
  • db_cooper
    +2 for the Kicker speaker upgrade.  Breaking them in right now.  They will get pretty loud, and have decent bass.  Much cleaner sound so I expect watching movies to be a nicer experience.
  • DougH
    DougH Member Posts: 1,110
    edited January 2019
