Planning life as a solo traveler. One of my big worries is having someone walk off with my batteries, propane or even the trailer itself!
What are the security steps you take on the road (like, when you go into a rest stop or restaurant,) and then once you get to your camping spot?
And do you change/modify the door lock on your Tab?
1 ·
( https://www.homedepot.com/p/Everbilt-3-1-2-in-Black-Key-Locking-Hasp-20404/203340006 ).
I purchased a black hasp primarily because it complements the two rubber hold-downs on the tub. However, you may prefer to use a stainless steel/chrome hasp. If it works out, I may post some photos of this modification, but others may have already done that (I haven't checked yet). Since this particular hasp includes a lock, it will be important that the hasp lines up with the lock. Therefore, I have already made a 1/2" spacer that will be located under the base of the lock portion of the hasp. The spacer will allow the lock to be raised far enough out from the tub so that it lines up with the hasp (which will be mounted on the edge of the overhanging tub lid). You can accomplish the same thing with a regular hasp and padlock if you prefer. (Greg) [EDIT: @Sharon_is_SAM may very well be correct regarding locking the tub while towing the camper. The LPG doors on my previous trailers all were non-locking. However, I do not tow with the propane on, plus I can always leave the tub unlocked while towing, if necessary. Also, I am primarily concerned with securing the tub while my camper is in storage away from my home, so leaving it unlocked while towing will not be an issue.]
2019 Ford F-150 3.5L Ecoboost with Long Bed
SF Bay Area
