Took our new 400 down south to leave it for the winter. Used it for three nights and yesterday noticed the latch bolt was sticking a little.I boughf some dry lube and sprayed it but it didn't seem to help much. Today as we were leaving it would not catch in the striker plate. I adjusted the striker plate out a little and it is now catching in the striker plate but I still have to play with it to get the latch bolt to come out all the way. Anyone else had this problem? Just wondering if I need to open it up and put some sort of lube in the mechanism?
BigGrover
2019 T@b 400 Boondock Lite
2018 Ram 1500 Quad Cab Hemi
Central Alabama
0 ·
Central Alabama
Central Alabama
@Verna Loctite will hold it in position. They sell red and blue. One is for screws that need to be removed from time to time but which you do not to vibrate loose. The other is a more permanent formula but still can be removed if needed. I can not remember which is which but it will say on the tube.
Anyone: What is the purpose of those screws on the door latch?
Central Alabama
Central Alabama
Huntington LI
Central Alabama
Sold 2023 Tab 400
Sold 2018 T@B 320S
Central Alabama
