Thanks for the link to the T@G board. A lot points to the wiring although mentioned error lights differ and changing the wiring didn't work for all. I will explore before cutting holes for additional vents. I appreciate all the time you have spent and the suggestions.
Hi, just saw this thread and wanted to add my two cents. I just this weekend had to replace my fridge because it over heated and burned up. Here's some pics. IMHO, NuCamp should have added more ventilation from the start!!
Seitzmike, I’ve scanned this thread see you’ve gotten a lot of good advice. More ventilation will certainly help your fridge’s efficiency on hot days with the hatch closed but won’t solve the cut-off problem while running on battery. While trying to make your model fridge work in our 2009 T@da, I discovered that while the voltage at the battery was 12.2 or lower, the voltage at the fridge dropped to below 11.5v and so the fridge cut-out. The T@da’s wiring wasn’t heavy enough for the 5+ amps drawn by the Norcold causing excessive. I installed an Engel fridge that draws 2.3 amps instead — no voltage drop. Heavier wiring will reduce the voltage drop to the Norcold and keep it running longer while on battery only. But imo the current draw and 11.5 cut-off make the Norcold I’ll-suited to boondocking.
If you have the Norcold model N180.3, that heat pattern is interesting since the exhaust is ventilated at the top not the bottom. I wonder if the exhaust ducting got disconnected on the installation.
‘18 Tab 320S- mfg’d 4/17, acquired 9/17 Spare & bike rack on tongue, Renogy 100w suitcase connection, cargo & door nets, sway bar, wired rear camera, Norcold aux fan, front window protection, frame mounted sewer & water hose storage, Krieger 1500w inverter w/100Ah LIFePO4. ‘24 Ford F150 XLT PowerBoost- 11,000# capacity ‘20 Honda Pilot Elite- 5000# tow cap, 500# tongue cap Huntington LI
What model and year TaB do you have?
Huntington LI
