Leaky compartment screenshot
Nice work. Did you share the name of the dealer who did the repair?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
I didn’t know if I should. JD Sanders RV Gainesville, FL. They’re the Airstream dealer but also sell lots of other brands. They’ve been here 40 years or more.2017 Tab 320 S
2014 Mazda CX 5
Traveling very light to be kind to my transmission.0 -
It flooded only that compartment. I dried it out thoroughly with a little heater and then a fan.lkc001 said:Yea--there should be an access panel to reach those fittings . . . . not good. Did it flood that entire front portion of the trailer? That would be my concern.2017 Tab 320 S
2014 Mazda CX 5
I have replaced both of those hoses that enter and leave the water pump. I replaced them with stainless steel which is a little more flexible and absorbs the pump vibration a little better. Since those connections only need to be hand tight no tools needed I had no problem doing it through the existing access door. No need to see only feel the connection with one hand.
- Hash T@B Fun
@melpeter, was the leak at the entry of the city water and fresh water inlets or at the pump hosing?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
All of the above, they told me.Sharon_is_SAM said:@melpeter, was the leak at the entry of the city water and fresh water inlets or at the pump hosing?2017 Tab 320 S
2014 Mazda CX 5
