Leaky compartment screenshot
2»
    Nice work.  Did you share the name of the dealer who did the repair?
  • melpeter
    melpeter Member Posts: 112
    I didn’t know if I should. JD Sanders RV Gainesville, FL. They’re the Airstream dealer but also sell lots of other brands. They’ve been here 40 years or more.
    2017 Tab 320 S
    2014 Mazda CX 5
    Traveling very light to be kind to my transmission.
  • melpeter
    lkc001 said:
    Yea--there should be an access panel to reach those fittings . . . . not good.    Did it flood that entire front portion of the trailer?  That would be my concern.
    It flooded only that compartment. I dried it out thoroughly with a little heater and then a fan.
    2017 Tab 320 S
    2014 Mazda CX 5
  • Dalehelman
    I have replaced both of those hoses that enter and leave the water pump. I replaced them with stainless steel which is a little more flexible and absorbs the pump vibration a little better. Since those connections only need to be hand tight no tools needed I had no problem doing it through the existing access door. No need to see only feel the connection with one hand.
    1. Hash  T@B Fun
    @melpeter, was the leak at the entry of the city water and fresh water inlets or at the pump hosing?
  • melpeter
    All of the above, they told me.
    2017 Tab 320 S
    2014 Mazda CX 5
