Just wondering if folks are leaving the yellow pressure relief/drain valves in the open position after draining the hw tank? I am concerned it might ultimately lead to leaks by weaking the springs in the valves.
BigGrover
2019 T@b 400 Boondock Lite
2018 Ram 1500 Quad Cab Hemi
Central Alabama
0 ·
We thoroughly drained and blew out the plumbing until it was dry, dry, dry and we closed our drains. Spencer the Alde rep made it clear that, even if a little water is left in the Alde tank, it is unlikely to cause problems with a freeze.
