Hello all! #1--should I use a dedicated RV 30 amp extension if needed to go from the Surge Protector which is plugged into the garage outlet to the trailer 30amp power cord, or is there some other kind of heavy duty extension cord that can be used? #2---is this the correct order of plug-in? Surge protector in garage/house outlet, then 30amp step-down to 20 amp dog-bone, then 30 amp extension cord, then trailer 30 amp power cord to trailer outlet?
Thank you
2016 Nissan Frontier SV V6 4x4
Finally! New Owner of a 2017 Tab 320S!
Woohoo!
1 ·
20 amp to 30 amp adapter, then 30 amp surge protector/EMS, then 30 amp extension cord, followed by TaB 30 amp cord
Be aware of the potential amp draw of the Alde (16 amps) on the 15 amp outlet.
Woohoo!
As to #2, assuming you have a 30-amp connector in the garage, the order is:
1) 30amp wall outlet
2) surge supressor
3) 30 to 20 dogbone
4) 20 amp extn cord
5) 20 to 30 dogbone
6) 30 amp cable to trailer
This is because the wall out let is a specialized 30-amp outlet and the trailer is a 30-amp twistlock outlet. In between to extend with a 20amp you need to go up and down the outlet conversion process.
Woohoo!
Woohoo!
Woohoo!
Go through this site here as it's specific for your 320.
https://jenngrover.com/jenns-top-answers-and-troubleshooting-steps-for-tb-320-owners/
People have run the AC on 2000w generators with no problem so technically, your 20-amp connection would be OK. BUT, those generators have cutoff switches to protect themselves and the cable used is a 30-amp and is very short. We hvae no idea how long your 20-amp extension cable will be, nor the quality of its wiring, the ambient temperature, what other devices may be using that circuit drawing down on it's available power nor what over equipment you might be running in the T@B. So, while I personally wouldn't run the AC but would run a 30-amp circuit to the garage so the T@B could be self sufficient, others here will say they've done it with no problem. And likely they have; but, the information above is from 20-years in the electrical industry. What works fine in NY at 72-degrees on a good quality extn cord doesn't translate so well in Texas at 101 degrees on a Home Depot special.
The 16-amps for Alde mentioned above refers to running Alde while also running the electrical elements as well. You can get heat using propane for a much lower amperage budget. To give you some perspective, I've attached the boondock calculation spreadsheet for the 400. The figures for Alde using electrical elements or AC are greyed out because they draw so much you need to be connected to shore power.
There was one done for the 320 perhaps even by Jenn but I think you can see from this one here that each electrical device has a specific draw. You have a budget for electrical consumption sort of like calories for the day and when you've used up your allotment, that's it.
Also included a section on the Alde because it talks about the propane vs electric settings which may be helpful to you. I have a 400 so may be talking out of my shoe on the 320 but electrical draw is the same regardless of RV make or model.
Woohoo!
The AC is on it’s own 110 circuit with a 20 amp breaker, so it should be fine on your garage outlet up to 20 amps. Not sure how often it actually draws a full 20 amps and keep in mind, you will also want to run the separate AC fan, too.
I know everyone is giving you great information, but each has their own way of relaying it, and I know if I'm rereading, or double checking to make sure I understand everything, you may be confused too, so I have explained what I have set-up and done exactly to eliminate any obtuse information. I have had my trailer hooked up in my backyard for almost 3 years this way, so I'm pretty sure there is adequate power to do the things i have detailed.
Btw, since my trailer is plugged into an exterior outlet on my house, it has gfci protection, should there be water intrusion into my cord connections. If you are plugging into an interior outlet your power source will probably not have gfci protection, which is ok if the t@b is also stored inside, but if the plug is interior and the cord runs outside if the t@b is stored outside, I would have gfci protection installed. That is my only item to check in what you want to do.
If you have any questions, don't hesitate to ask. -Denise
Woohoo!
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
This is a connector you can use on the camper end: https://www.amazon.com/gp/product/B00002NAT8/
The other parts are available from your local hardware (Home Depot, Lowes, etc) stores. Unless you know that you will need this cable when camping, you can just leave it at home and use the standard power cord for camping. I have a 12 gauge 25' version of this cord for connecting to a small generator w/o any adapters.
Woohoo!
This thread has been very helpful as I'm thinking about how to safely plug my Tab 320s into the electricity at my sister's house, and then at a friend's house. I have three questions though, that I have searched for answers to, and cannot find. I would greatly appreciate anyone's advice!
1) if i use my 15-30 amp adapter to plug into a 20 amp outlet, am I then limiting my amps to 15 (the adapter?) or will I still benefit from the 20 amp outlet? is this safe?
2) if the answer to #1 is no, can someone please share where i can find a 20-30 amp adapter? i am having trouble finding one...
3) my friends have regular household outlets and also a 220v outlet in their garage. I understand that the 220v is a NO-NO, but am wondering if this is true even with a voltage adapter? they say their other friend uses an adapter and plugs her camper van into the 220v outlet... i am worried about this given the emphasis people place on not using this kind of outlet...
thanks very much for whatever advice you can offer!
#2 NA
#3 Not sure what adapter you are referring to but it sounds like a step-down transformer. They are big and bulky and I'm not sure how well they'd work in this application, but if you get one big enough (maybe in the 3000 or more watt range) you might be able to eke out a few more amps than a standard 110-120v household circuit would provide. But they get hot and are inefficient and most can't be left outdoors.
Let me preface this by saying you should use a surge protector when you plug in anywhere.
1. Just to be sure, check your breaker box in the house or garage that supplies the outlet that you are going to use. That is the best way to know to what you are limited in terms of amps - it should be 15 or 20 amps. As JEB said, your 15 to 30 adapter will carry the amperage from the outlet that you use.
2. You can use your 15 - 30 amp adapter in a regular household outlet. That is what we use.
3. RVs and Motorhomes require either 30 amp or 50 amp supply for full use of their appliances. As you know, the 30 amp is supplied by 110 - 120 volt current at a campground pedestal using our funny looking plug. Larger MH with their many electrical appliances, require 50 amps and it is supplied by 220-240 volt current using a different plug that delivers 120 volts to 2 separate poles on the plug. If you have a 30 amp to 50 amp ADAPTER PLUG (not a voltage adapter) for RVs you can use the 240 volt outlet. Then only 120 volts will be delivered from the 240 volt outlet as only 1 leg of the outlet is used and you are limited to 30 amps. If you go this route, make sure the adapter plug that you use matches the 240 volt outlet pattern. You should plug in the adapter into the outlet, then plug in the surge protector into the adapter and let the surge protector determine the line voltage before you plug in your TaB.
(The concern with folks using a 240 v outlet usually involves someone not knowing what your RV needs. I have heard horror stories of someone somehow wiring a 240 volt supply with a 30 amp outlet and you can guess the outcome.)
If you are using a 15/20 amp household outlet to power your camper, you could make a dedicated power cord for that purpose by purchasing a 25' 12 AWG extension cord, cut off the female end, and purchase and attach a 30 amp female RV connector in its place. Now you can leave your 30 amp cord stashed and use the dedicated 20 amp cord at home. A cord like this is also really handy for connecting to a 2000/2200 watt generator too.
Here's a connector that will work just dandy for that.
https://smile.amazon.com/gp/product/B00002NAT8/
northwestinatab's application is residential, and a dryer outlet is the most likely candidate. If so, then he could just use his existing 30A cordset and this adapter, available at Home Depot. Would this work?
