Has anyone added a fixed awning to their 400? I have just about every Pahaque awning/tent and I never seem to use them. I would like to pull up to a campsite and pull out the awning (yes- I am lazy). I would also like something bigger than what Pahaque offers. The only solution I can come up with is to put a roof rack on the trailer and attach something like a Yakima or Thule awning to the rack. Problem is it will probably look really ugly
| Girl Glamper | Austin, TX | 2018 Land Rover Discovery | 2018 T@B 400 |
Partner in Crime: Black pug (Lulu)
1 ·
My Visor takes less than 10 minutes install, including staking it to the ground or to water jugs.
There is a competitor who has the option of a straight visor on a curved camper, and it just totally looks out of place.
(These are my personal opinions.)
https://www.winfieldsoutdoors.co.uk/camping/tents/inflatable-tents/
https://www.kampa.co.uk/awning/sunshine-air-pro-300
(about $400)
These are all inflatable.
https://www.kampa.co.uk/awnings?cat_type=awning&vehicle=1&awning_frame=6
Concept Awning.
1. Three tubes that extend across the roof of the tab are fastened to the roof with hardware using the keder rail for a fastening point. One tube aft, one in the middle and the the third forward. The distance between the tubes forms the extent of the awning, or front to back length, with the middle position forming the ridge of the awning. Each tube has a storage element that is fastened to the roof and an interior tube that extends.
2. The rolled up awning is contained in the front or back tube. Pull the awning out, fold down the leg support, the pull it back or forward over the extended othe tubes and fasten to the third tube. The awning is rolled around another tube that fits inside the main tube.
3. The other two tubes also pull out to support the rolled out awning.
4. The pulled out elements would have fold down adjustable legs to support the outer ends of the tubes.
5. To roll up: unfastened the secured end; insert crank into the storage tube, and roll up. Fold up legs and return rolled up awning and other extended supports into their tubes. Insert tube caps and voila. QED.....perhaps.
6. The concept is simple but as with most things, the devil will be in the details.
Richard
St Catharines, ON
Check out this awning from @WilliamA on his TaG.
